Author Topic: 69 Small Block driveshaft length  (Read 5780 times)
sixt9x33rs
« on: July 28, 2011, 09:43:34 PM »
Is the length of the driveshaft different if a car came with a Saginaw or Muncie? Small Block application.
Re: 69 Small Block driveshaft length
« Reply #1 on: July 28, 2011, 11:03:00 PM »
The P & A manual lists a unique part number for all '69s w/Muncie 4-speed.
sixt9x33rs
« Reply #2 on: July 29, 2011, 12:20:43 AM »
Wonder if the difference is length, diameter or what?
« Reply #3 on: July 29, 2011, 02:31:46 PM »
The AMA specs document shows the same length, diameter, and wall thickness dimension for 3-speed, 4-speed and automatic small-blocks (49.56" x 2.75" x .065"); the different part number in the P&A book for Muncie-equipped cars may relate to U-joint yoke indexing. Service prop shafts were just the shaft, with no U-joints or slip yokes.
« Reply #4 on: July 30, 2011, 04:06:14 PM »
sixt9x33rs,
You can check out this thread if you have time.
http://www.camaros.org/forum/index.php?topic=7861.0;all
sixt9x33rs
« Reply #5 on: July 31, 2011, 03:02:45 AM »
sixt9x33rs,
Hi Byron,
I have checked it out and a good one.
I will give the info regarding my Z28 and the L65 convertible I just got.
sixt9x33rs
« Reply #6 on: July 31, 2011, 03:08:48 AM »
Thanks John...I was wondering if a Muncie could be installed in place of a Saginaw...guess so.
