Author Topic: Fuel Filter Canister Clamp - SB BB, same?  (Read 2902 times)
oneZ11
« on: July 28, 2011, 08:08:13 PM »
Made for both small block and big block engines?  Was it the same part#?
Heartbeat City says "Camaro fuel filter canister clamp.This clamp is used on all 350/255hp, 350/300hp, 396/325hp, 396/350hp engines with Quadrajet carburetor and vapor return line."
I thought they would be different.
tmodel66
Re: Fuel Filter Canister Clamp - SB BB, same?
« Reply #1 on: July 28, 2011, 08:22:06 PM »
They are the same.  These are the only engines that used the big canister type filter with a return line.
Daniel
oneZ11
« Reply #2 on: July 28, 2011, 09:00:36 PM »
So there must be a bolt hole mount that's works the same for both. Where does it mount on the SB? Intake manifold bolt?
tmodel66
« Reply #3 on: July 28, 2011, 09:30:16 PM »
Nope the SB don't get a mount bracket like the BB. SB just sorta hangs in the wind so to speak. The fuel lines are pretty tight and stiff so you'll have no problem.
Daniel
oneZ11
« Reply #4 on: July 29, 2011, 01:56:55 AM »
So, correct is no canister clamp for SB?
Boston14
« Reply #5 on: July 29, 2011, 01:59:38 AM »
Correct
boston14
boston14
1969 SS/RS 350 Convertible
