Author Topic: Opinions needed....67 Body  (Read 9363 times)
Buddy
« on: November 01, 2005, 09:52:35 PM »
I would like to hear differing opinions on how to finish the under carriage as well as frame and rearend from bare metal to finish. I will be starting mine in a couple weeks when I get it back from sheetmetal work. Also would like to know what the factory did?
Thanx
Buddy
Re: Opinions needed....67 Body
« Reply #1 on: November 02, 2005, 04:29:42 PM »
From the factory, the underbody was gray primer with some body color overspray on the outer edges from the guns that sprayed the bottom of the rockers.  :)
Buddy
« Reply #2 on: November 03, 2005, 07:25:11 PM »
I guess a good plan would be to use a good epoxy type coating the color of primer gray for the underside then let the body overspray give it the original look. Thanx..Buddy
protofab
« Reply #3 on: November 10, 2005, 02:39:53 AM »
We spray the under carriage after sand blasting with Por 15 then sand the sand it lightly to knock off the shine and spray it black.
Looks real good when its finished.
sebastien
« Reply #4 on: November 10, 2005, 03:03:25 AM »
yep, POR15 works good.
Sebastien
Sebastien 68  327 rag top
Buddy
« Reply #5 on: November 14, 2005, 02:31:36 PM »
What is the difference between POR15 and DP90?
Thx
Buddy
waynechipman
« Reply #6 on: December 20, 2005, 05:55:01 PM »
Have heard of other products that are less expensive than Por 15, like ever free is one I think. Is Por 15 the king. I am close to doing the pans and trunk on mine. Money of course is a consideration, But I want this to last and to not have to do it again. Thanks
Buddy
« Reply #7 on: December 26, 2005, 04:24:30 PM »
Just did mine with black DP90 and it looks killer.
