Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Rear Axle Carriers
« previous
next »
Print
Pages: [
1
Author
Topic: Rear Axle Carriers (Read 3638 times)
cadmanof50s
Member
Vic Brincat
Rear Axle Carriers
on:
June 24, 2011, 07:08:29 PM »
I have not been able to find any thing in-the CRG site on the different carrier series.
Is there a link that explains the differences and how one can identify which is which.
Thanks!
Vic
Tweet
Logged
Vic Brincat
1968 Camaro RS Convertible - 327
Hero Member
Re: Rear Axle Carriers
Reply #1 on:
June 24, 2011, 07:49:02 PM »
Vic, there will be a casting number on the carrier. Post that number and we can tell you what you have.
Logged
cadmanof50s
Member
Vic Brincat
Reply #2 on:
June 24, 2011, 10:49:03 PM »
Thanks Ed,
I did have this number from an old picture I took a while back. But this is the Axle Code: BP0228G2 which tarnslates (below). I will get the casting number when I crawl under the car tonight.
Thanks!!
(Since 1968) it is a 2.73 Ratio 10 bolt - not posi
Built February 28th (1968)
at the Detroit Gear & Axle plant
in Shift 2
Vic
Logged
Vic Brincat
cadmanof50s
Member
Vic Brincat
Reply #3 on:
June 25, 2011, 12:39:45 AM »
The casting number is 3894859 NF.
Logged
Vic Brincat
Hero Member
Reply #4 on:
June 25, 2011, 01:13:40 AM »
Vic, the 3894859 is the casting number of the center section (some call it the "pumpkin") on the 10 bolt rear end. You can read more
HERE
Logged
cadmanof50s
Member
Vic Brincat
Reply #5 on:
June 25, 2011, 01:54:56 AM »
Sorry Ed. This shows my ignorance.
Where do I look for the carrier casting number?
Do I have to remove the differential back cover to determine which series is in the rear axle?
Logged
Vic Brincat
Hero Member
Reply #6 on:
June 25, 2011, 02:47:38 AM »
The 2.73 axle used a 2 series carrier, so if the car still has this gear set, no, you don't have to remove the cover.
Logged
cadmanof50s
Member
Vic Brincat
Reply #7 on:
June 25, 2011, 02:50:16 AM »
Thanks for the info Ed.
Vic
Logged
Vic Brincat
Print
Pages: [
1
« previous
next »
General Discussion
Rear Axle Carriers
