Author Topic: Bolt & Clip Color  (Read 3299 times)
IZRSSS
  • Guest
Bolt & Clip Color
« on: June 15, 2011, 03:19:59 PM »
What is the correct color for the Rear A/C Compressor Brace bolts & the Vacuum Advance Clip (orange, gray phosphate or black)?
Re: Bolt & Clip Color
« Reply #1 on: June 15, 2011, 04:43:53 PM »
The L-48 vacuum advance line clip is orange - it was on the engiine when it was painted.
IZRSSS
  • Guest
« Reply #2 on: June 15, 2011, 05:02:03 PM »
Thank you John...I also figured out the A/C brace bolts were on the engine during paint.
Much appriciated!
« Reply #3 on: June 16, 2011, 04:45:11 PM »
Much appriciated!
Nope. Those two (painted) intake manifold bolts were removed and discarded, and replaced with two #179841 bolts when the brace was installed; see your AIM, section C60, sheet C7, item #3.
IZRSSS
  • Guest
« Reply #4 on: June 16, 2011, 04:49:20 PM »
Just in time...was just about to mount the brace.
Thanks John
