Author Topic: 67 BB Engine Gaskets  (Read 3608 times)
big iron
« on: May 13, 2011, 12:51:41 AM »
I has been awhile since I put an original engine together and need help on original gasket type selection. In what areas, if any where cork gaskets used? ???
Bob
tmodel66
Re: 67 BB Engine Gaskets
« Reply #1 on: May 13, 2011, 01:37:22 AM »
The oil pan, timing cover, each end of the intake and valve covers.
Gramps69Z
  • 69 X33 D80
« Reply #2 on: May 13, 2011, 01:40:24 AM »
And if I remember right the water pump to block had cork gaskets.
Captain John Wykoff
tmodel66
« Reply #3 on: May 13, 2011, 01:41:55 AM »
I was thinking (which is dangerous) the water pump got paper gasket.
Gramps69Z
  • 69 X33 D80
« Reply #4 on: May 13, 2011, 01:45:35 AM »
Daniel, it's been so long since I've seen a set of original gaskets, but many years ago I've seen cork water pump gaskets.
Captain John Wykoff
big iron
« Reply #5 on: May 13, 2011, 01:58:56 AM »
What about the distributor ,water pump to rear plate and carb. to air filter housing? The valve cover gaskets where painted silver. I think the fuel filter was black paper.
Bob
tmodel66
« Reply #6 on: May 13, 2011, 02:20:18 AM »
Your probably right John. I'm like you it's been a long time.
The distributor  and air cleaner is yes. Not sure about water pump but I think it was cork too.
