Author Topic: 69 L48 Starter  (Read 12130 times)
IZRSSS
  • Guest
69 L48 Starter
« on: April 25, 2011, 10:08:50 PM »
I am trying to find a Starter for a 69 L48 (350/300HP) auto. The part # is 1108420. One other catch...it needs to be dated prior to 12A (1st wk of Dec. 68).
If you know of one, or have one please send me a PM.
Thanks guys!
« Last Edit: April 25, 2011, 11:21:40 PM by IZRSSS »
Re: 69 L48 Starter
« Reply #1 on: April 25, 2011, 10:34:16 PM »
I am trying to find a Starter for a 69 L48 (350/300HP) auto. The part # is 110840. One other catch...it needs to be dated prior to 12A (1st wk of Dec. 68).
Thanks guys!
Marty, are you sure about that number (110840)?    ???
Re: 69 L48 Starter
« Reply #2 on: April 25, 2011, 10:49:53 PM »
Should be 1108338 starter (Powerglide) or 1108420 (Turbo 350).
(Assuming you just made a typo and need the 1108420...)
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #3 on: April 25, 2011, 11:02:52 PM »
I left out the 2 but I still had time to add it before time expired...
Thanks Paul & Ed!
« Last Edit: April 25, 2011, 11:28:36 PM by IZRSSS »
crobjones2
Re: 69 L48 Starter
« Reply #4 on: April 26, 2011, 08:54:51 AM »
Any idea when the change happened on the production line?
Chris
69 SS 350
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #5 on: April 26, 2011, 12:38:44 PM »
Chris,
I am not really sure when the change over occurred or if there was one (although you would think there was since the problem was brought to GM's attention on Dec. of 68). Here is a good discussion referencing these starters. Down towards the bottom of the thread you will find starter usages confirmed by Kurt. As long as your car and starter application fall within these... it should be fine.
Note; Jerry's book lists the following starters: SS350 (L48) Manual Trans-1108338, & SS350 (L48) Turbo 350-1108420
 http://www.camaros.org/forum/index.php?topic=2779.msg17843#msg17843
« Last Edit: April 26, 2011, 01:11:49 PM by IZRSSS »
crobjones2
Re: 69 L48 Starter
« Reply #6 on: April 27, 2011, 03:56:38 PM »
Marty
I believe I have the original starter for my L48 TH350 combo, 420 dated 9E12. (engine assenbly of T0525)
I have seen conflicting reports as to what the car should have come with from the factory, and have been told the 420 was a dealer replacement for the 361.
Until recently I havd never seen the technical bulletin
Guess I no longer need to search for that proper date coded 361
Chris
Chris
69 SS 350
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #7 on: April 27, 2011, 04:45:52 PM »
Chris,
I think the credit should go to Jonsey for supplying us with the service tech bulletin.
Here's where it gets complicated...or maybe not...since the 420 & the 338 were replacements for "Hot Cranking" problems associated with the 361 it would be difficult for anyone to say, regardless of dates on these replacements, if these would be correct applications for anyone trying to assemble their L48's with "#'s parts"...just one guys opinion.
crobjones2
Re: 69 L48 Starter
« Reply #8 on: April 27, 2011, 05:50:33 PM »
I would assume at some point during the production year, only the 420 was installed on the production line.  If so, any idea as to when that may have happened?
Chris
69 SS 350
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #9 on: April 27, 2011, 08:25:05 PM »
According to the thread I posted it seems like the jury is still out on that one. Although I hope there is enough information now so that  someone can give us the answer.
Re: 69 L48 Starter
« Reply #10 on: April 29, 2011, 01:50:05 AM »
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #11 on: April 29, 2011, 01:58:58 AM »
Kurt,
Kurt, thank you for posting the link.
Do you have any information with regards to Chris's question? I think his question would also have to include the rest of the replacement starters. In addition, do you think the correct date as it relates to the replacements & the build date of the car pose any issues for a numbers car?
« Last Edit: April 29, 2011, 03:00:05 AM by IZRSSS »
Re: 69 L48 Starter
« Reply #12 on: April 29, 2011, 02:07:46 PM »
That TSB indicate early, so clearly before Dec 23. But they don't mention a transition date and I haven't seen it in other docs either.
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #13 on: April 29, 2011, 02:47:52 PM »
Kurt,
Thanks again. Still a tough call since we don't have a transition date. I think the safest assumption would be (at least in my case) to find a replacement that is prior to Dec 23. At least until a transition date has been established.
I would certainly like to here from judges, officials, or other core members with your recommendations.
tom
    • Discount Internet Services
Re: 69 L48 Starter
« Reply #14 on: April 29, 2011, 04:15:29 PM »
Marty you should be able to find a local rebuilder who can rebuild any original starter to higher standards. Years ago I had the 6 volt starter on a truck rebuilt as  a 12 volt starter. Then you could have the required performance with a numbers correct starter.
69 X11 Z21 L14 glide
o
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #15 on: April 29, 2011, 05:54:15 PM »
Thank you Tom.
tom
Re: 69 L48 Starter
« Reply #16 on: April 29, 2011, 06:25:17 PM »
Make sure you find a competent rebuilder. Some shops are better than others.
o
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #17 on: April 29, 2011, 07:50:17 PM »
Good sound advice, will do. First I have to find the correct starter. The one in the car works great...it just isn't the correct one.
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #18 on: May 10, 2011, 12:29:51 PM »
Can someone tell me when the 1108420 starters were first put into production for use on first gens?
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #19 on: May 10, 2011, 09:47:26 PM »
Okay...lets try this. If someone was to change the windings in the 1108361 to convert it into a high torque starter, would this take care of the "Hot Cranking" issues. Since the 420 is so dad-gum hard to find it seems like this would be a viable alternative.
tmodel66
Re: 69 L48 Starter
« Reply #20 on: May 10, 2011, 09:53:55 PM »
Marty don't quote me on this but I believe the high torque starter housing is longer than a regular starter. I've run into this on several applications.
Daniel
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #21 on: May 10, 2011, 10:00:45 PM »
Just my luck. What about a May 69 420? Would this be an acceptable replacement date? I think I know the answer but I thought I'd ask anyway. :-\ Seems to me a replacement date should fall within 3wks to not more than 2 months after the bulletin. Any thoughts?
tmodel66
Re: 69 L48 Starter
« Reply #22 on: May 10, 2011, 10:10:52 PM »
No idea about that. Best to let the heavy weights get in on the tech bulletins and dates. I'll keep my eye open for a core on a 420.
Daniel
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #23 on: May 10, 2011, 10:12:45 PM »
Many thanks!
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #25 on: May 11, 2011, 12:03:50 AM »
The April 69 starter has been there for quite sometime.
I really like the May 69 starter. It popped up a couple days ago & really got my attention. I think I'll hold off until the heavy weights weigh in, or better yet...JUDGES... WHERE ARE YOU ???. My take is that no one can estimate when, or even if a car owner went to a dealership to honor such a bulletin/recall. Which means just about any date within reason would work after December 23, 1968 as long as the owner has in his or her possesion a copy of the TSB for judged purposes. Any thoughts ???
Thanks Chris! Keep em comin! But can you PM me instead?
« Last Edit: May 11, 2011, 12:26:08 AM by IZRSSS »
Re: 69 L48 Starter
« Reply #26 on: May 11, 2011, 05:34:37 PM »
This was not a recall, and owners had no knowledge of TSB's; TSB's just notified the dealers of potential field complaint issues and suggested a fix for them if they got a customer complaint.
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #27 on: May 11, 2011, 06:00:22 PM »
Thanks for explaining the meaning of TSB's. I think this reinforces what I stated earlier in that it would be difficult for anyone to dispute a reasonable replacement starter date with regards to the 8420 if a person opts to go that route. However, I am in communications with a savvy retired engineer who might have the answer for modifying the 8361 so that it works like it was intended to.
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #28 on: May 11, 2011, 06:21:59 PM »
I checked into this Dan...this high torque modification will not alter the exterior configuration of the 8361.
