Author Topic: Horn not working  (Read 4946 times)
LILT
Horn not working
« on: April 06, 2011, 11:10:26 PM »
I have a 69 the horn is not working I replaced the relay now when I press the horn button it makes a clicking sound with no sound from the horn
tmodel66
Re: Horn not working
« Reply #1 on: April 06, 2011, 11:15:11 PM »
Spray some WD-40 into the horn and knock the H*** out of it with a stick. I know it sounds silly but it works.
Charley
« Reply #2 on: April 06, 2011, 11:45:36 PM »
I agree..Bang on it with a piece of wood.
WayneinNZ
« Reply #3 on: April 07, 2011, 09:43:08 AM »
Or.............................
You could invest in one of these bumper stickers..................
« Reply #4 on: April 07, 2011, 03:40:47 PM »
Disconnect the green horn wire connector from the plug on the bottom of the horn relay. Push the horn button (so the relay clicks) and check for power on that terminal - if you have power, the relay is OK. Now run a jumper wire from the battery (+) terminal to the horn terminal; if the horn doesn't blow, it either isn't grounded properly, or it's dead.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #5 on: April 07, 2011, 06:05:38 PM »
http://www.camaros.org/forum/index.php?topic=7451.0
You might find the above helpful if you haven't seen it already.
Richard
Richard Thomas
1969 RS
