Author Topic: Original 67-69 Camaro driveshafts - information requested about your car  (Read 288814 times)
Thanks Petes L48
Anybody else?
302V8
1968 z28 ,   norwood,  03c,   302,   muncie m20,  49.96 length,    ubolt and nut design,   bu-0214-g1 axle stamp,   2 strips about 12 down from top,  staggered alignment.
Thanks 302V8.
Are the stripes white and orange?
302V8
The strips are so faint,   the look white to me.   thanks.
Petes L48
Finally remembered to post this:
67 LOS, 11B build, L48 w/ Pglide
49.5 inches center to center, yokes are # 3790024 rear is 280A and front 280D
U bolts, axle is PC1031G 3:31, yokes are clocked
Replaced my front u-joint this weekend and found orange and light green paint markings on the yoke:
Thanks Pete!
shaftmasters
Re: Original 67-69 Camaro driveshafts - information requested about your car
« Reply #97 on: August 06, 2012, 12:31:36 PM »
 I think that I know why there is a 1/2 inch difference in driveshaft lengths between the '67-68 and '69 driveshafts but want info to verify. I believe it is because there is a difference in lengths of the transmission yokes being used for these years. Can anyone measure their transmission yokes from center of u-joint to end of yoke and report their findings. Be sure to include what year yours is. They should measure either 4.875 inches or 5.5 inches.
tmodel66
« Reply #98 on: August 06, 2012, 04:12:10 PM »
My '69 L48 is 5.5 inches. I thought when we rebuilt the driveshaft it was the wrong one but checking another for verification it was correct. My driveshaft is also clocked and that brought on a bunch of weird looks and a big discussion at the shop until the post about the drivehsafts come up.
Daniel
shaftmasters
« Reply #99 on: August 06, 2012, 04:49:39 PM »
So I am guessing that your driveshaft measures approximately 49.5 inches long. If you had a driveshaft that measures closer to 50.0 inches long I would guess the transmission yoke to measure 4.875 inches long.
Louis M
« Reply #100 on: November 19, 2012, 01:41:13 AM »
I just joined so Im new to this forum. I do have a 67 convertible camaro origianlly with a 6cy. and a 50" driveline on a PG. I removed the PG and engine for a TH400 and a 454.
The driveline fit but it has NO room for movement.
The Th400 has 31 splines i believe.
I need approx 1/2 to 3/4 inch more room.
Im going to order it from "Inland Empire Driveline" and go pick it up as i live in OC.
They have a website with all the pertinent info to order a correct one. Looks like they come with 1310 Spicers.
FRom what I gather, the big block sits back a little and thus I need a shorter driveline.
I will ask the guys tomorrow and just order it new, as I dont want any problems from not having enough room for movement, however, I do believe the original big block 49.5" would have worked.
The one I currently have is 50" from center of U-joints.
This forum helped me get my measurements correct.
louis
tom
    • Discount Internet Services
« Reply #101 on: November 23, 2012, 11:49:27 AM »
Before you order the new shaft, check your motor mounts. I think there were different mounts for small block, big block, and 6 cyls. I am told you can move the engine forward or backward a little bit by using different mounts. Might be worth a little time.
tom
69 X11 Z21 L14 glide
o
« Reply #102 on: December 14, 2012, 08:29:22 AM »
I don't think that is the reason for the different lengths.  From above...here is what I have been able to find out...
For 67 and 68 cars with the 396, different frame mounts for the engine were used which pulled the engine forward about 1/2 to 3/4 inch.  Also note the holes for the 396 cross member for use with a manual transmission had the transmission mounting holes about 3/4 inch forward.  The PG, TH350, 3 speed manual and 4 speed manual transmissions are all close to 27 5/8 or 27 3/4 inches long (including bellhousing length).  But the TH400 is slightly longer - around 28 1/4 inches.
67 and 68 Camaros used two different lengths.  49.96 inches for all applications except the 396 with manual trans which was 50.46 inches.
69 Camaros all used the same length, 49.56 inches.  This appears to be due to the frame mounts all being the same for the big blocks and small blocks.  Although I can't find anything listed, it seems the TH400 driveshaft should be slightly shorter.
So that is why I am looking for actual measurements, to confirm these numbers.
« Reply #103 on: February 20, 2013, 09:10:44 PM »
Anybody else?
67conv6cyl
« Reply #104 on: February 20, 2013, 11:50:16 PM »
I have original unrestored drive shaft, The car is 67 04A norwood convertible, 250 engine 3 speed manual trans, measurement form u joint to u joint is 50".
