Author Topic: Original 67-69 Camaro driveshafts - information requested about your car  (Read 288797 times)
Re: Original 67-69 Camaro driveshafts - information requested about your car
« Reply #210 on: April 15, 2019, 12:21:03 AM »
Hello all, hope someone can help me with my confusion. I've ordered u-joints from 2 different sources, based on the vehicle specifics, but when I got them, the first ones didn't fit the pinion yoke. Reordered and then they didn't fit the driveshaft yoke. This lead me to read through the CRG driveshaft report, several times along with this 14 page thread. I thought I had the original correct driveshaft, but know I don't think so. The car is a 68 10A L35/TH400 car. The 12 bolt rear has a pinion yoke that takes straps and cap screws, with 1.06 dia. bearing caps but the width is @3 1/2". Cant seem to find a u-joint with the correct dimensions. If I've read the resources right, the driveshaft should be 49.96" length, in-line yokes, with HD u-joints (at both ends?) If this is correct, I'll need a combination u-joint at the rear that has the wider, large diameter caps on one axis, and the smaller 1.06 caps with the same width on the other? The driveshaft I have is 49.96, has small standard u-joint on one end, and TH400 yoke with injection molded HD u-joint at the other. Any help is appreciated.
There are 3 sizes of u joint. 1310, 1330, 1350.
Are you sure your pinion yoke is original?
I believe the the driveshaft side uses a 1310 u joint that is about 3 1/4 inches wide.
The 1330 and 1350 are larger, like 3 5/8 inches wide.
There is a u joint available with 1310 on one side and 1330/1350 on the other. Sounds like that’s what you need.
Measure and check. Any local parts store SHOULD have one or can order one.
x1169
« Reply #211 on: April 15, 2019, 03:44:25 AM »
Thank you sir, for your response. Not sure if yoke is original, but the 12 bolt had correct date code, and gm gears dated to match car. If both u joints on the Th400 driveshaft are supposed to be the same size/ part number, the pinion yoke seems incorrect. So, the 396/Th400 driveshaft should be 49.96" with in line yokes and uses 1350 joints at each end?
« Reply #212 on: April 15, 2019, 12:16:05 PM »
You did not say what year car. Check the table in the report for correct length.
You will have to measure the u joint size on the driveshaft - like you did on the yoke - to make sure it will fit.
x1169
« Reply #213 on: April 15, 2019, 05:49:20 PM »
1968, 10A Los car, i've measured the driveshaft i have. It is 49.96, but has outside clips on both joints, small 1.06 caps, with a Th400 yoke????? If this ones not correct, Ill look for a right one, but need to know which combo is correct. Thanks
« Reply #214 on: April 15, 2019, 10:41:56 PM »
49.96 is the correct length.
Does your rear u joint area look like this?
http://www.camaros.org/images/ds/uj_stand.jpg
If so, this should be a standard 1310 u joint.
Post pics of what you have or email pics to me.
x1169
« Reply #215 on: April 16, 2019, 10:32:33 PM »
Here is the yoke that's on the 12 bolt now. measures out to need a 1330 joint. 1 pic shows a 1310 held in place to show issue. After all the research, I re-inspected the driveshaft. It is apparently incorrect for this car. While its length is correct, the yokes are offset, uses 1310 ujoint, and has a Pontiac TH400 yoke with a 1310 joint....as soon as I can verify what is correct, I guess I'll be looking for a driveshaft....thanks again for all the help...
« Reply #216 on: April 16, 2019, 11:07:14 PM »
I am not so sure that yours is wrong.  I think it will work. You just need the proper u joints.
« Last Edit: April 17, 2019, 12:54:13 AM by bcmiller »
x1169
« Reply #217 on: April 17, 2019, 03:36:05 AM »
I thought the 396/Th400 shaft for 68 had in line yokes?
« Reply #218 on: February 01, 2020, 03:38:47 AM »
Yes, sorry, they should be inline.
« Reply #219 on: February 08, 2020, 12:25:47 AM »
Any 1969 4 speed COPO or 4 speed L78 driveshafts out there that show strip color?
Daytona Z
« Reply #220 on: February 08, 2020, 07:59:47 PM »
Here are a few pics of the original driveshaft in my 69 Camaro
1969
X77 Z/28
M-20
Norwood
Late Build Nov 69 - 10E
Clocked @ 30deg
Orange White Stripes @ 11" from tip
49-5/8" Length w/ Straps
BU 1028G1 (Strikeout C Prefix)
Just an obsessive-compulsive first gen car guy...
did I mention I like three pedals in a car?
« Reply #221 on: February 08, 2020, 10:14:39 PM »
Thank you! Every data point helps.
« Last Edit: July 19, 2021, 04:23:38 PM by bcmiller »
09E COPO.  M40
Not on my pc so I can’t modify the photo from being upside down.
So what would you say the colors are from front to back?
I would say, but don’t want to influence what you see.
« Last Edit: July 19, 2021, 06:24:36 PM by bcmiller »
x66 714
If you don't get an answer before MCACN, there will be a L78 M22 survivor car there...Joe
