Author Topic: Original 67-69 Camaro driveshafts - information requested about your car  (Read 288736 times)
Re: Original 67-69 Camaro driveshafts - information requested about your car
« Reply #240 on: January 11, 2022, 01:06:26 AM »
pink
« Reply #241 on: January 11, 2022, 01:16:43 AM »
That’s purple.  Get yours eyes checked old man!  Lol
« Reply #242 on: January 11, 2022, 01:44:33 AM »
LoL ???
Agreed-Violet!
1968 LOS L35/TH400
68SSL35/M40/O2
« Reply #243 on: January 11, 2022, 08:54:59 PM »
LoL ???
Agreed-Violet!
1968 LOS L35/TH400
where did you get the crayon/paint marker for the stripes?
68SSL35/M40/O2
« Reply #244 on: January 11, 2022, 08:58:09 PM »
LoL ???
Agreed-Violet!
1968 LOS L35/TH400
Or buy what you have left over.
« Reply #245 on: January 11, 2022, 09:56:18 PM »
I used a Testors Enamel Model paint set and mixed and blended my own paint on a plastic cup to a degree this "old mans eyes" felt it matched the remnants were on the shaft.
This photo is 1995 when I had the shaft u-joints replaced as a part of regular owner servicing.
I just poof canned the tube and used a 3/4" brush applied based on the spacing mine had, including the green on the end of the Yoke.
Material source: Gloss Enamel 7-bottle Paint Kit 9115X
I didn't know about the Quanta striping sources back then either & Testors is affordable alternative to this:
https://www.gastanks.com/Inspection-Paint-PURPLE-2-oz/productinfo/Q-120/
« Reply #246 on: January 11, 2022, 10:18:20 PM »
Duco paint is what was called for. It was probably applied at the time of balancing.  See driveshaft report for more info.
These were applied with a brush and of course there was variation in width and spacing depending on the person doing the job.
Sometimes I am not good at describing colors. That one stripe is kind of a purple/pink mix.
« Last Edit: January 11, 2022, 11:47:24 PM by bcmiller »
« Reply #247 on: January 12, 2022, 04:33:57 PM »
Magenta.   ;D
samz
« Reply #248 on: March 01, 2022, 03:53:41 AM »
1969
Norwood
Oct. 5week
302
M20
Approx. 49.5"
Strap and bolt attachment
BU(12 bolt, 3.73 gears, posi.) 10(Oct.) 23(Day) G(Detroit Gear and Axle Plant) 1(shift) E(Eaton Axle) 5(?)
U-joint flanges (clocked)
« Reply #249 on: March 01, 2022, 12:02:48 PM »
Thank you Scott.
You can see what we have compiled so far in the report at this link.
http://www.camaros.org/driveshaft.shtml
KevinW
« Reply #250 on: March 01, 2022, 01:33:12 PM »
Very good information!  I want to check all my yokes and driveshaft now for the correct improved 69 versions.  But one question and maybe a clarifying note on the article...  How is the driveshaft length measured?  Tip to tip, or centerline of U-joints? thx
« Reply #251 on: March 01, 2022, 02:20:04 PM »
Note: All lengths are measured from centerline to centerline of the universal joints.
KevinW
« Reply #252 on: March 01, 2022, 10:58:13 PM »
Thanks!
« Reply #253 on: October 17, 2022, 04:17:03 PM »
Year of car (1967)
Norwood or Los Angeles car (LOS)
Month and week of vehicle assembly (05C)
Engine (396/375 4K)
Transmission (Manual)
Driveshaft length (50-1/2” )
Driveshaft casting number (not observed yet)
Type of attachment to pinion yoke. (U bolts method)
Code stamped on front of passenger side axle tube. (QC 0510 G1)
Paint stripes and a picture (Orange-Green-White)
Position of the u-joint flanges on each end. (in-line)
Additional Green Dab towards Balance weight.
« Reply #254 on: October 17, 2022, 07:49:35 PM »
Thank you Jim!
There won’t be a casting number. I will repost what we need for future posts.
Year of car
Month and week of vehicle assembly or VIN
Engine
Transmission
Driveshaft length (measured center of u joint to center of u joint)
Type of attachment to pinion yoke. There are two types: U bolts / the straps and bolts method.
Ratio and assembly date code stamped on front of passenger side axle tube.
Paint stripes and a picture (if possible)
Position of the u-joint flanges on each end. Some cars were "in-line" and others were "clocked" about 30 degrees off from each other
