Author Topic: Fender Camaro Emblem on SS  (Read 4450 times)
srode
« on: February 05, 2011, 01:54:00 AM »
What's the correct placement for the Camaro Emblem on an SS car?  I have an original fender (I think) to use to create a template on a virgin OEM fender for holes, but on the original the holes look like it will not place the emblem straight, instead a little at an angle (slightly).  Are these supposed to be straight / parallel to the fender line and the ground or a little at an angle?  Also, is the placement the same on an SS and a non SS car?
Thanks, Steve
IZRSSS
  • Guest
Re: Fender Camaro Emblem on SS
« Reply #1 on: February 05, 2011, 02:22:50 AM »
Maybe this will help...
IZRSSS
  • Guest
« Reply #2 on: February 05, 2011, 02:23:15 AM »
And...
IZRSSS
  • Guest
« Reply #3 on: February 05, 2011, 02:26:26 AM »
Measurements...
Stingr69
« Reply #4 on: February 05, 2011, 11:45:16 AM »
Those AIM dimensions are near worthless. They all reference from a pair of imaginary lines that you do not have.
-Mark.
srode
« Reply #5 on: February 05, 2011, 11:56:31 AM »
The picture is helpful as are the hole sizes.  I have to admit looking at the AIM dimensions I am lost as to how to use them other than as a template creator - the tilt and location aren't really specified.  Looks from the picture to level not tilted any.
« Reply #6 on: February 05, 2011, 03:19:28 PM »
The body inch lines (designated by the numbers in the circles) were part of the GM Body Dimensional Grid system, which was used to set the body up on a surface plate for height-gage measurement vs. the design master. Those inch lines are perfectly vertical and horizontal in a 3-dimensional grid system.
srode
« Reply #7 on: February 05, 2011, 03:41:06 PM »
thanks John, I that helps decipher the information - I'll take it over to the shop this morning.
IZRSSS
  • Guest
« Reply #8 on: February 05, 2011, 03:48:55 PM »
I believe these are the two main reference points...
X and Y axes {15 & +5} are there simply to keep your holes perpendicular to one another...
