Author Topic: Correct color for the rear leaf spring “BM” tags?  (Read 2550 times)
Dave69x33
« on: January 19, 2011, 11:32:52 PM »
According to Jerry MacNeish’s ’69 Camaro fact book, the rear “BM” tag for the 3934894 leaf springs was silver paper with black lettering.  When I initially restored my ‘69Z, in 1995 – 2000, I purchased silver or light gray tags with the black lettering from Rick’s 1st Gen., when Rick George still owned and operated the store.  I need to replace the tags but now, I can only find yellow tags with black lettering.
Which is technically correct?
Based on JM’s book and my previous purchase of silver/light gray tags, I tend to believe that silver/light gray paper is correct.
Does anyone still have original springs with the BM tags still intact on springs, and provide a picture to confirm the color?
If I recall correctly, the assembly manual indicates a color code on the exterior eyelet surface of the spring.  At one point in time, was the spring color coded then a switch to color coded tag used?
Thanks in advance for your input.
