Author Topic: Heater box seal  (Read 4930 times)
cadmanof50s
  • Vic Brincat
Heater box seal
« on: December 29, 2010, 05:04:02 PM »
Just preparing everything I need to put my '68 back together again.
According to the AIM, the inside heater box used the dash mat as the seal to the inside of the firewall. Also according to the AIM, the outside heater box cover used a sealing compound to the engine-side firewall.
I have seen gasket sets (available through the normal vendors) that  provide gasket seals for both these applications. Are these gasket sets correct? (Should I be using them?)
If sealer/caulking  is correct, what would be an appropriate sealer to use?  Black silicon...??? Body caulking? Could someone recommend a product please.
Thanks!!
VIc
Vic Brincat
1968 Camaro RS Convertible - 327
Re: Heater box seal
« Reply #1 on: December 29, 2010, 06:02:02 PM »
No separate gaskets were used originally. Black RTV is a good substitute for the bead of sealer used on the heater blower case groove.
KevinW
Re: Heater box seal
« Reply #2 on: December 30, 2010, 01:06:06 PM »
I used electrical putty (Dum-Dum) rolled out in a bead to seal the outer cover.  I used the putty (used for sealing wires piercing house walls and sold in lowes, Home depot) in a LOT of places, kick panels, rear bumper mounts, tinnerman nuts, cowl squirter seal, etc.
cadmanof50s
  • Vic Brincat
Re: Heater box seal
« Reply #3 on: December 30, 2010, 01:13:39 PM »
Thanks John and Kevin.
I like the idea of using the Dum-Dum as it stays pliable. That's very handy if (for whatever reason) you needed to remove the cover.
Vic Brincat
68rs327conv
    • The build
Re: Heater box seal
« Reply #4 on: December 31, 2010, 03:07:40 AM »
You can still buy the 3M 8578 Strip Caulk
68 RS Conv 327/210hp, Powerglide Factory AC
BlackoutSteve
Re: Heater box seal
« Reply #5 on: December 31, 2010, 05:56:32 AM »
..or body sealer listed on page 167 (B-11608) It's what I used to seal my heater box cover and a bunch of other things.
http://www.amkproducts.com/Catalog_PDF/165-176.pdf
KevinW
Re: Heater box seal
« Reply #6 on: December 31, 2010, 01:40:23 PM »
I like the Electrical putty because its a dark charcoal, the strip caulk you can get in stores is a beige.  AMK wants a $30 min order last I looked + ship.  HD or Lowes is a lot cheaper (under $10 I think) and I am there a lot anyway :)
BlackoutSteve
Re: Heater box seal
« Reply #7 on: January 01, 2011, 02:28:53 PM »
They do, but are you saying you can't find other stuff to order?
Everytime I flick through their catalog, I have a another list as long as my arm! :P
KevinW
Re: Heater box seal
« Reply #8 on: January 01, 2011, 05:21:15 PM »
I do have a wish list fo AMK, but then I mostly find what I need in my misc bolt boxes. :)  When I get stuck, i will put in an order :D
