Author Topic: 1968 Z28 smog tubes  (Read 24932 times)
Jerry@CHP
Re: 1968 Z28 smog tubes
« Reply #15 on: December 02, 2010, 04:55:27 AM »
The '67 right side tube is shorter and the check valve is completely different and will work without cleanace issues.  It' bends off on 2-45 degree angles.  The '68 tube is taller and won't work like that.
It's just the way it is.  Back in the day, no one ran smog and a cowl plenum AC.  My Chevelle was two weeks old when I ripped off the smog and threw it in the trash.
Jerry
fireZ
« Reply #16 on: December 02, 2010, 09:44:00 PM »
Is that 67 smog tube still available?I would use that instead of cutting up and rewelding a 68 tube
1968 Z28 LA Built
LIC # RPO Z28
« Reply #17 on: December 02, 2010, 10:07:54 PM »
Exactly what I was thinking!
Jerry@CHP
« Reply #18 on: December 02, 2010, 11:35:42 PM »
It's a completely different tube with different bends, and the check valve is different with two ports on 45 degree angles.  NG.
Jerry
Flowjoe
« Reply #19 on: December 07, 2010, 06:32:35 PM »
That is a good question.  I can tell you that most people did not get the headers because it doubled the cost of the Z28 option.  Not cost effective.  And the Hooker headers were a better header so most added them after the purchase of the car.  I have only seen two documented cars that had both.  My white car and Sam Bishop's dark green Z28.
If you experienced living back in the day, this all makes sensebut to many of the younger generation people who are trying to restore a car today, it's difficult to process why and how things happened back then.
Jerry
Jerry
I know of a '68 in the SF Bay area that has both factory headers and the CP - if that's at all helpful to your data Jerry.
Jerry@CHP
« Reply #20 on: December 08, 2010, 01:30:27 AM »
Flowjoe,
Yes if it's a documented car with paperwork.
Jerry
fireZ
« Reply #21 on: January 06, 2011, 09:09:10 PM »
How would a car be judged if it had the correct 1968 cowl plenum and had the original exhaust manifolds with plugs in the smog holes? Second question is my car came with CP in backseat when I got it years back but the pop with the  car does not denote the CP anywhere on pop
1968 Z28 LA Built
LIC # RPO Z28
fireZ
« Reply #22 on: January 07, 2011, 05:43:24 PM »
What pipe plugs were used.Hex head or allen key plugs?
1968 Z28 LA Built
LIC # RPO Z28
« Reply #23 on: January 07, 2011, 07:00:38 PM »
P/N 3889330 hex-head 1/4"-18 straight pipe thread plug.
fireZ
« Reply #24 on: January 08, 2011, 06:47:20 PM »
are the plugs an indented hex head?
1968 Z28 LA Built
LIC # RPO Z28
« Reply #25 on: January 14, 2011, 12:29:35 AM »
Socket = indented
Hex Head = 'raised' Hex head
fireZ
« Reply #26 on: January 14, 2011, 01:11:17 PM »
Thanks for that explanation
1968 Z28 LA Built
LIC # RPO Z28
