Author Topic: cowl plenum  (Read 9693 times)
fireZ
cowl plenum
« on: October 23, 2010, 04:54:15 pm »
When a cowl plenum was purchased did the screws to attach the duct to the firewall come in the package also. I have seen different types of screws used. What is correct. thanks as always.
1968 Z28 LA Built
LIC # RPO Z28
IZRSSS
  • Guest
Re: cowl plenum
« Reply #1 on: October 24, 2010, 12:26:56 pm »
fireZ
Re: cowl plenum
« Reply #2 on: October 24, 2010, 07:55:51 pm »
I did see that picture and then I looked at cars at Carlisle and some of them had a small hex screw holding the duct. I cant make out the picture of Jerrys white car to see what is on that car.Thanks again   ??? ???
1968 Z28 LA Built
LIC # RPO Z28
IZRSSS
  • Guest
Re: cowl plenum
« Reply #3 on: October 25, 2010, 03:56:25 am »
Take a look at the pics on this site and their attention to detail. There is a white '67Z under the customer car section w/cowl plenum. This might be the source your looking for...
http://lucas-restorations.com/default.aspx
fireZ
Re: cowl plenum
« Reply #4 on: October 25, 2010, 02:24:01 pm »
I seen that car but when I try and blow the picture up it becomes distorted.
1968 Z28 LA Built
LIC # RPO Z28
IZRSSS
  • Guest
Re: cowl plenum
« Reply #5 on: October 25, 2010, 02:36:23 pm »
Point...if you take the time to look at their site you will see a section where cars have been meticulously disassembled piece by piece. I am not absolutely certain, but they may have pics of the screws you are looking for.
Go to their home pg and send them an email. You can access this under "Contact Us". Sometimes these things take a little leg work.
Good luck
Jerry@CHP
Re: cowl plenum
« Reply #6 on: October 25, 2010, 02:37:59 pm »
5/16" indented head screws that are black phosphate in color.  Originals are on my white car.
Jerry
fireZ
Re: cowl plenum
« Reply #7 on: October 25, 2010, 03:13:32 pm »
Thanks Jerry ,you are a great guy to share your knowledge on these cars. Thanks once again Paul Bruce
1968 Z28 LA Built
LIC # RPO Z28
tom
    • Discount Internet Services
Re: cowl plenum
« Reply #8 on: October 25, 2010, 06:45:46 pm »
When you are resizing pictures, look for a option, or check box to preserve the aspect ratio. That will keep them from distorting.
69 X11 Z21 L14 glide
o
john302
Re: cowl plenum
« Reply #9 on: October 25, 2010, 10:28:25 pm »
Do the screws have a built on washer? any head markings? I realize that there were different bolt suppliers . thanks John
fireZ
Re: cowl plenum
« Reply #10 on: October 26, 2010, 10:06:42 pm »
I think they have a built in washer  ??? ???
1968 Z28 LA Built
LIC # RPO Z28
Charley
Re: cowl plenum
« Reply #11 on: October 30, 2010, 02:45:43 am »
So Jerry are you saying the phillips headed screws on my 67 Z are incorrect ?
