Author Topic: 67 power feed wire  (Read 4966 times)
big iron
67 power feed wire
« on: October 17, 2010, 03:18:50 AM »
Anyone have a picture of the firewall piercing for the 67 power feed wire A31/C06?
Bob
big iron
Re: 67 power feed wire
« Reply #1 on: October 19, 2010, 12:03:50 AM »
 Correction that should be power lead not power feed.
Bob
Bob
« Reply #2 on: October 19, 2010, 03:37:28 PM »
A31 didn't have a firewall piercing - it was fed from the fuse block.
x66 714
« Reply #3 on: October 19, 2010, 07:44:25 PM »
Unless 67 is different the 68/69 for power windows and/or power top there should be a wire going through the firewall. There's a wire (black) that comes from the horn relay & goes to the circuit breaker that's attached to the firewall behind the m/c power booster. The wire coming from the circuit breaker (orange w/blk) goes through the firewall. It has a small grommet attached to it. There's a dimple in the firewall where you would need to drill. It's discussed in the assm manual. If I'm not mistaken it's near the upper LH bolt for the pedal mount. I can look tonight if that would help....Joe
x66 714
« Reply #4 on: October 20, 2010, 01:20:33 PM »
I gave you the wrong info. The wire going through the firewall is next to a ground strap below the wiper motor....Sorry.
Joe
big iron
« Reply #5 on: October 26, 2010, 02:39:58 AM »
Sorry for the delay and thanks for the responce.
JohnZ, you are correct in that the window relay coil (A31) was fed from the fuse box but the window motors where feed from the circuit breaker(C06) on the firewall.
Joe, the power lead wire is different for 69 than for 67,68. Are you sure that your original reply was not correct?
Bob
big iron
« Reply #6 on: November 02, 2010, 12:39:23 AM »
No 67's with electric windows or convertibles w/ power top?
Bob
x66 714
« Reply #7 on: November 03, 2010, 01:23:17 PM »
MY first reply was mostly correct except fot the placement of the hole for the wire that goes through the firewall , at least for 68/69. I don't have an assm manual for a 67 to check. C06 show the harness placement & A31 say to refer to C06....Joe
