Author Topic: 68 big block a/c  (Read 2962 times)
monaroman
68 big block a/c
« on: October 12, 2010, 10:49:06 PM »
Hi there,
Sadly, the wiring was been removed from the selector switch in the dash through the fire wall and out to the engine bay.
I have the correct wiring set up now and want to install it.
It looks like a big job to hook up the wiring to the blower fan.
Im hoping someone has a trick up there sleave, or do i have to remove fender/inner wheel well???
Cheers.
big iron
Re: 68 big block a/c
« Reply #1 on: October 14, 2010, 02:08:42 AM »
Everything you need to know about your BB AC wiring is in the 68 AIM UPC C60 starting with E1. Two wires to the blower motor and the ambient temperature switch and they are all plug in. If you have long arms you may be able the install the wiring without removing the inner fender-well.
Also look at view A C60 D5, if the cap is not installed the bolt will do a job on unprotected arms, that are trying to install for mentioned wiring.
Bob
monaroman
« Reply #2 on: October 14, 2010, 06:08:41 AM »
Hi Bob,
Thank you for your advice i shall give it a very carefull go.
Cheers.
