Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
4 spd shifter hole for a 69
« previous
next »
Print
Pages: [
1
Author
Topic: 4 spd shifter hole for a 69 (Read 5470 times)
x66 714
Hero Member
on:
October 07, 2010, 09:49:35 PM »
I have a piece of a floor that I cut out a 67 or 68 years ago. I don't remember if it was automatic or std from the 67 or not. My question is how close could it be for use on a 69? Was the hole always in the same spot for 3spd/ 4spd trouugh out the 67/69?
Thanks, Joe
Tweet
Logged
mark x22
Member
Re: 4 spd shifter hole for a 69
Reply #1 on:
October 08, 2010, 12:34:43 AM »
I think 1969 is different than 1967 /68 .
Logged
Kelley W King
Hero Member
Reply #2 on:
October 08, 2010, 11:40:08 AM »
When my 69 was redone the guy had a 68 Hurst shifter he located the hole with. I later got a 69 shifter and installed it. It would not go into 2nd or 4th until I reworked the floor to move the the hole back.
Logged
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
big iron
Hero Member
Reply #3 on:
October 08, 2010, 02:20:17 PM »
Just dug out a reinforcing plate for a 67 and the front to rear hole spacing is 5 1/2" (5.500) and side to side is 4 3/8" (4.375), so the 69 is longer 1" (1.00) and narrower (1.065). I based these numbers using markx22's post.
Figuring that the spacing from the "V shaped crease in the floor" to he forward mounting hole is the same for 67-69, then that would explain the problem with the 2nd and 4th shifter problem.
Being that the 68-69 both use the same console. How did the factory get around the shifter placement difference? I would think they would have to change the placement of the consoles.
Bob
Logged
x66 714
Hero Member
Reply #4 on:
October 08, 2010, 03:28:28 PM »
Thanks for everybody's imput. I've forwarded the info to a guy who's replacing the entire floor pan. A problem we don't have in Tucson....Joe
Logged
mopar346
Member
Reply #5 on:
October 09, 2010, 11:51:31 PM »
MarkX22,
Any chance of getting larger/clearer diagrams e-mailed??
Thanks, Kevin
Logged
mark x22
Member
Reply #6 on:
October 10, 2010, 01:00:42 AM »
I tried emailing to myself and couldn't print or see any better . That's the best resolution i get as a JPEG picture . I can print clear out of the original drawing program but it loses quality converting to JPEG for photo bucket or email . I can try redrawing with bigger text which one do you need ?
Logged
mopar346
Member
Reply #7 on:
October 10, 2010, 03:35:59 AM »
No need to go to any trouble, I actually don't have an immediate need, just collect as much documentation as I can, you never know when you might need something.
Thanks, Kevin
Logged
Print
Pages: [
1
« previous
next »
Restoration
