Gramps69Z
« Reply #75 on: October 04, 2010, 06:04:47 PM » |
Please take that Ford sticker off it.
Logged
Captain John Wykoff Destin Fire 3 to go
I'm sick and tired of mismanagement and disappointment. I'm a COWBOYS fan.
IZRSSS
Guest
« Reply #76 on: October 04, 2010, 06:41:53 PM » |
I don't mind you criticizing the car but can you be more specific WYKOFF.
Logged
Boston14
« Reply #77 on: October 04, 2010, 06:47:18 PM » |
I believe he is refering to the big ugly red CAUTION sticker which came on Fords not Chevrolets.  boston14
Logged
boston14
1969 RS/SS 350 Convertible Dover White with Black Top and D90 stripe, Red Standard Interior
IZRSSS
Guest
« Reply #78 on: October 04, 2010, 06:50:38 PM » |
That's all he had to say...
Logged
Gramps69Z
« Reply #79 on: October 04, 2010, 07:20:17 PM » |
By all means I was not criticizing your car. I think it's beautiful and your very lucky to have found it. As much research that you've done I'm surprised that was not pointed out to you before....
Logged
IZRSSS
Guest
« Reply #80 on: October 04, 2010, 07:31:30 PM » |
Thanks...  Who makes the best replacement stickers?
« Last Edit: October 04, 2010, 08:45:42 PM by IZRSSS »
Logged
Mark
« Reply #81 on: October 05, 2010, 06:00:03 AM » |
There are no stickers on the radiator shroud of a Camaro, only the tune up spec sticker that goes on the core support, unless the car had A/C and then it went on the front edge of the radiator shroud.
Logged
Mark C. 1969 Indy Pace Car 350/300HP RPO Z11
IZRSSS
Guest
« Reply #82 on: October 05, 2010, 06:23:53 AM » |
Thank you Mark. The sticker has been pulled  Was the tune up spec sticker (info) standard for each application? Are there any good repro's? Most of the stuff I get is at Rick's...do you have a preference? Also, would you happen to have a pic of an original TUS applied to a '69? Thanks
Logged
IZRSSS
Guest
« Reply #83 on: October 05, 2010, 10:30:09 AM » |
Thanks John... ...any ideas on how to bring back the shine?
Logged
IZRSSS
Guest
« Reply #84 on: October 06, 2010, 08:21:24 PM » |
Also, would you happen to have a pic of an original TUS applied to a '69? Certainly someone has a pic
Logged
Jeremiah
« Reply #85 on: October 06, 2010, 11:09:51 PM » |
I have had two unrestored AC equiped cars, one had the decal in the center of the shroud and the other was on the side. I probably depended on who was working the line at the time and what they thought looked best?
Logged
69 SS/RS Hugger orange-Ivory houndstooth, endura. 69 RS Conv. Black/Black-Ivory interior, endura, DX1.
IZRSSS
Guest
« Reply #86 on: October 07, 2010, 06:10:38 AM » |
You mentioned you had the cars. If you do not have the cars anymore would you happen to have pics of their engine bay? If so can you please send them to me, either here or to my email address?
Actually, just saying center or side is probally good enough. These stickers weren't applied by robots.
Thanks J
« Last Edit: October 07, 2010, 06:45:56 AM by IZRSSS »
Logged
lakeholme
« Reply #87 on: October 07, 2010, 07:55:28 AM » |
For the tune up spec sticker, the best thing to do is follow what the 69 AIM says.... A little WD40 followed by some rubbing compound might get some of that old glue out from the CAUTION sticker. I'd try this in an unnoticable place first. There is a sticker remover on the market, but I've never tried it.
Logged
Phillip HNR-AACA, Senior Master "Charlotte AutoFair -- presented by the Hornets Nest Region, AACA -- is the largest and greatest Collector Vehicle Event in the Southeast."
IZRSSS
Guest
« Reply #88 on: October 07, 2010, 08:33:49 AM » |
Thanks Phillip. I'll try your advise for the caution sticker.
I have the '69 Assembly Manual and in B1 "Labels & Stickers", no reference is made with regards to a Tune Up Spec sticker. Am I looking in the wrong place? I'm assuming this is AIM...
Logged
« Reply #89 on: October 07, 2010, 09:36:21 AM » |
It's on that sheet. It's item #3 in view "A", to be positioned 3.5" to the left of centerline on top of the radiator support. Although not shown on that sheet, if the car had A/C and the rubber hood seal across the top of the radiator support, it had to be placed elsewhere (on the shroud).
Logged
'69 Z/28 Fathom Green CRG
