'69 Radiator questions
(1/1)
Dave69x33:
Fan Shroud Clips:
Based on the '69 Assembly Instruction Manual (AIM), Section UPC 11, page 147 covering the original installation of the radiator and related components, I assume the fan shroud clips were not painted, and originally black/dark gray phosphate plated?
I also base my assumption from the attached picture I took of an original survivor '69Z "UH" code radiator.
Overflow hose clip:
Was the overflow hose retained with a clip (like the repro "BC" code clip sold by Heartbeat City, Item EGP-2111), or did the side tank have a stamped-in hose retainer? The attached picture shows the clip but it is not called out as a separate detail part number in the AIM.
Correct drain cock:
Can anyone confirm who sells the correct drain cock with the "ears" pointing toward the engine?
Painted radiator ID tag:
If recall correctly, that tag was added to the side tank before the radiator was painted and thus painted along with the radiator.
Thanks in advance for your help!
JohnZ:
The shroud clips were phosphated, and the overflow hose clip was part of the radiator assemblly as received from Harrison.
Camaro Billy:
Here is the only correct looking petcock I know of.
http://www.danchuk.com/ItemForm.aspx?item=400
It looks good with the hose off
Billy
Dave69x33:
Camaro Billy,
I'll give Danchuk a call...thanks.
JohnZ,
Do you still have your original radiator in your car, and is the rad overflow hose clip painted?
JohnZ:
--- Quote from: Dave69x33 on May 27, 2010, 11:10:13 PM --- JohnZ,
--- End quote ---
Yes, it has the original "UH" radiator, and the clip appears to have been painted with the radiator.
Navigation
[0] Message Index
