Author Topic: 302-Z-28 factory original timing chain and gears  (Read 7432 times)
rally
« on: May 25, 2010, 11:33:31 AM »
Gentlemen did Chevy from the factory use the heavy duty morse link chain and wider cam and crank gear set? Its a heavy duty set, wider plastic cam gear and wide crank gear that was used on the 67-69 model years, is this a legit factory install or a over the counter buy at the  GM delearship?
« Last Edit: May 25, 2010, 12:05:20 PM by rally »
Re: 302-Z-28 factory original timing chain and gears
« Reply #1 on: May 25, 2010, 03:18:45 PM »
The Z/28 used the same timing chain (3896961), crank sprocket (3896959) and cam sprocket (3896960) as all other 327 and 350 engines; nothing unique to the Z/28 302 engine in that area.
rally
« Reply #2 on: May 25, 2010, 07:53:19 PM »
Thanks John, appreciate the info. Apparently these heavy duty sprokets and chains were availiable over the counter at GM High Perf catalogs. Some one on ebay is selling this set and claimed these came on the 302 Engines from the factory. Thanks again for setting this straight.
« Reply #3 on: May 25, 2010, 08:08:12 PM »
That would be Sam & Dolly Graffz...
http://cgi.ebay.com/ebaymotors/1967-1969-Camaro-Z28-302-NOS-GM-Timing-Chain-67-68-69-/110537739986?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item19bc900ed2
Jerry@CHP
« Reply #4 on: May 27, 2010, 02:27:27 AM »
Don't install that nylon cam gear in your engine.  They were junk.........still are.  I can't tell you how many friends trashed their engines when that gear started to come apart.  Bent valves, the whole ball of wax.  I changed the cam in my Chevelle just in time......was coming apart when we removed it.
Jerry
rally
« Reply #5 on: May 27, 2010, 06:12:34 PM »
Thanks Jerry very much for that info. I wondered why these types were not installed from the factory in these engines. Appreciate your help and honesty here Jerry. From a customer of yours, thanks again.
« Reply #6 on: May 28, 2010, 03:20:24 PM »
The auction has ended and some poor soul bid $307.00 for this "junk"!     :o
« Reply #7 on: May 29, 2010, 05:27:54 AM »
Maybe they're gonna build one of the 60,000 69 Z's that were made.  When your making an expensive car, no expense is spared.
