Author Topic: minimum rearend width  (Read 6624 times)
timmorgan
« on: May 13, 2010, 11:04:25 PM »
 Does anyone know what the minimum width for a 69 camaro can be without tubing?
timmorgan
Re: minimum rearend width
« Reply #1 on: June 14, 2010, 02:27:06 AM »
O.k. , I must have said some thing wrong. I know that with all the camaro knowledge you guys have that someone knows the minimum width rearend that can be put under a 69 without having to tub. I have a 9" ford that is 50" from backing plate to backing plate, 3" narrower than stock. I've been told this will be fine with proper back spacing. Please let me know your opinions. thanks!
flyingskibiker
« Reply #2 on: June 14, 2010, 03:36:37 AM »
Did you try Team Camaro?  LOTS of modifications going on over there!  Here, more original...
