June 19, 2013, 12:57:03 PM
Search:     Advanced search
83182 Posts in 10594 Topics by 4407 Members
Latest Member: georgeshaw
+  CRG Discussion Forum
|-+  Model Specific Discussions
| |-+  6-cylinder Camaros
| | |-+  Front Swaybar
« previous next »
Pages: [1] Print
Author Topic: Front Swaybar  (Read 4343 times)
L22K19
Member
View Profile Email
« on: April 25, 2010, 07:07:50 AM »
I have just noticed that my early 67 six cylinder car has no front sway bar fitted. From what I can see of the bounting bracket holes in the subframe have never had a bolt fitted to them. Is this a common thing?
Al
Logged
77thor
Member
View Profile WWW Email
« Reply #1 on: April 25, 2010, 10:05:26 AM »
I thought that all Camaro's came from the factory with a front swaybar...
but I'm no expert... still learning.
The real experts will chime in.
Logged
Fred - Milwaukee, WI
1969 Camaro SS 350, M21, 12 Bolt Posi - (probably a 'clone')
67ss350camaro
CRG Member
View Profile Email
« Reply #2 on: November 11, 2010, 03:40:00 PM »
Yes, I have noticed this before.  I assume that your car is an L22 by your user name?
Logged
Daniel
67 RS/SS 350 auto (owned since 81.)
97 V6 5-speed Coupe (work car ordered new)
2012 1LS (V6 6-speed) Coupe (new work car)
My Camaro
67conv6cyl
Member
View Profile
« Reply #3 on: February 23, 2012, 06:52:07 PM »
My 67 convertible 250 6cyl came with factory sway bar
Logged
CRG Coordinator
View Profile Email
« Reply #4 on: March 02, 2012, 03:39:42 AM »
Chuck's real early 08D L22 (250) also doesn't have a sway bar.
What's the build dates of your cars?
Logged
67conv6cyl
Member
View Profile
« Reply #5 on: March 05, 2012, 11:17:40 PM »
build date for my 250 is 04A has factory sway bar.
Logged
L22K19
Member
View Profile Email
« Reply #6 on: September 22, 2012, 07:04:55 PM »
My car is 02A and is a LA built car. I have since purchased a 6cyl Convertible that is 03C and it has a sway bar.
Logged
deputystoneman
Newbie
View Profile Email
« Reply #7 on: January 26, 2013, 08:10:40 PM »
The bushingsn
 are rotting on the front sway bar of my 68.
What size sway bar and brand is best for replacement of the entire thing.
Logged
CRG Coordinator
View Profile Email
« Reply #8 on: February 06, 2013, 08:30:55 AM »
So, sorting things like I always do.....
     plant eng swaybar
08D LOS 250  no
02A LOS 250  no
03C               yes
04A        250  yes
I have to say this is surprising. GM said only the 230 didn't have the swaybar in 67.
The swaybar bushings are readily available from most suppliers in rubber (original) and urethane.
Logged
67conv6cyl
Member
View Profile
« Reply #9 on: February 07, 2013, 05:35:16 PM »
May be all convertibles got swaybar?
Logged
CRG Coordinator
View Profile Email
« Reply #10 on: February 08, 2013, 12:57:11 PM »
Good point. I tend to think it didn't depend on body type, but I have no idea. Adding that into the mix shows we really need more data. Smiley
      plant eng      swaybar
08D  LOS 250 cpe  no
02A  LOS 250        no
03C               cvt  yes
04A  NOR 250 cvt  yes
*updated*
« Last Edit: February 11, 2013, 12:44:35 AM by KurtS » Logged
67conv6cyl
Member
View Profile
« Reply #11 on: February 08, 2013, 03:55:49 PM »
My 04A cvt was NOR built, just to add more data
Logged
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.093 seconds with 18 queries.
