Author Topic: What is this?  (Read 8357 times)
McKenzieDave
What is this?
« on: April 23, 2006, 10:30:10 PM »
1969 Camaro 327 with PG.  I know it's off the oil pan rail, but I am drawing a blank.  Thanks, Dave
ogbean
    • MySpace
Re: What is this?
« Reply #1 on: April 23, 2006, 10:37:44 PM »
It appears to be the battery cable bracket... it was bolted on with one of the oil pan bolts... missing most of the time
David
1968 L30 4spd ???, Rally Green, White Vinyl Top, Ivory Houndstooth Interior (716), D55 console, D91 Stripe
McKenzieDave
Re: What is this?
« Reply #2 on: April 23, 2006, 10:53:56 PM »
No, I have those too.  They are larger loops and coated.  Thanks, Dave
CNorton
Re: What is this?
« Reply #3 on: April 24, 2006, 01:04:20 AM »
Transmission cooler lines.  You are apparently missing the rubber insulators that secure the lines within the bracket.
Re: What is this?
« Reply #4 on: April 24, 2006, 03:45:11 PM »
That's the clip that goes on both sides (under a pan bolt) on cars with ram's horn exhaust manifolds to retain the front two plug wires on each side and hold them away from the manifold heat.
McKenzieDave
Re: What is this?
« Reply #5 on: April 25, 2006, 12:37:47 AM »
How'd that get in that pile??  Thanks John, it really had me going.  Dave
RJ_RS_SS_350
Re: What is this?
« Reply #6 on: April 26, 2006, 01:31:06 AM »
Wow, those must be long spark plug wires to go all the way down to the oil pan and then all the way back up to the distributor!
Re: What is this?
« Reply #7 on: April 26, 2006, 05:19:31 PM »
Yes, they are - and on a Corvette, the front two wires on each side are covered with a chrome heat shield.
