Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
What is this?
« previous
next »
Print
Pages: [
1
Author
Topic: What is this? (Read 8340 times)
McKenzieDave
Member
What is this?
on:
April 23, 2006, 10:30:10 PM »
1969 Camaro 327 with PG. I know it's off the oil pan rail, but I am drawing a blank. Thanks, Dave
Tweet
Logged
ogbean
Member
Re: What is this?
Reply #1 on:
April 23, 2006, 10:37:44 PM »
It appears to be the battery cable bracket... it was bolted on with one of the oil pan bolts... missing most of the time
Logged
David
1968 L30 4spd
, Rally Green, White Vinyl Top, Ivory Houndstooth Interior (716), D55 console, D91 Stripe
McKenzieDave
Member
Re: What is this?
Reply #2 on:
April 23, 2006, 10:53:56 PM »
No, I have those too. They are larger loops and coated. Thanks, Dave
Logged
CNorton
Member
Re: What is this?
Reply #3 on:
April 24, 2006, 01:04:20 AM »
Transmission cooler lines. You are apparently missing the rubber insulators that secure the lines within the bracket.
Logged
CRG Member
Re: What is this?
Reply #4 on:
April 24, 2006, 03:45:11 PM »
That's the clip that goes on both sides (under a pan bolt) on cars with ram's horn exhaust manifolds to retain the front two plug wires on each side and hold them away from the manifold heat.
Logged
McKenzieDave
Member
Re: What is this?
Reply #5 on:
April 25, 2006, 12:37:47 AM »
How'd that get in that pile?? Thanks John, it really had me going. Dave
Logged
RJ_RS_SS_350
Member
Re: What is this?
Reply #6 on:
April 26, 2006, 01:31:06 AM »
Wow, those must be long spark plug wires to go all the way down to the oil pan and then all the way back up to the distributor!
Logged
CRG Member
Re: What is this?
Reply #7 on:
April 26, 2006, 05:19:31 PM »
Yes, they are - and on a Corvette, the front two wires on each side are covered with a chrome heat shield.
Logged
Print
Pages: [
1
« previous
next »
Restoration
What is this?
