Author Topic: hurst shifter problem  (Read 4297 times)
kid56
« on: March 28, 2010, 11:51:55 PM »
Hi guys, having shifter problem,muncie M20 in 67 camaro, Hurst comp plus shifter. It used to have a spring action when putting it into reverse
(I assume it is a reverse lock out), now you can move the shifter freely( side to side in neutral) from reverse to 3rd and 4th with no resistance.
Is there a spring that has broken or does the shifter need rebuilt? I have adjusted the rods several times no help.
thanks for any help
Kid 56
67 ss/rs 396
flyingskibiker
Re: hurst shifter problem
« Reply #1 on: March 29, 2010, 06:30:23 AM »
I would hazard a guess that is a sping (or two).  I see them offered in the Hurst catalog...  A kit of 4 springs, 2 inner, 2 outer.  I have heard there are also rebuild kits.  Not sure what's included w/ those (springs?).
« Reply #2 on: April 01, 2010, 03:54:34 PM »
You could send it to Hurst if you don't have someone locally that rebuilds them.  Here is the link
http://www.hurst-shifters.com/c.723089/hurst-shifter/shifter_rebuild.html
m22mike
« Reply #3 on: April 03, 2010, 12:23:33 PM »
thanks for any help
Take a look at this picture, these springs are what you work against when moving to reverse (note: one of  the roll pins is missing in this picture.)
Or this plunger could be hanging up ? One thing for sure, you will need to take the shifter out. Note: on a working shifter clamped in a vice you can see how it works when moving the handle all the way left in the neutral gate.
67 ss/rs 396
May help to look at this for tear down, not the hard. Good luck.
http://www.yenko.net/ubbthreads/showflat.php/Cat/0/Number/410415/an/0/page/0#Post410415
kid56
« Reply #4 on: April 04, 2010, 03:37:55 PM »
thanks for the info guys and great pics
mike b
67 3L 4N
