Original coil bracket bolts
GaryL:
What is the head marking on the original/correct bolts?
Marty:
I picked a pair up probably 15 years ago in a junkyard. They are special bolts. The head markings are RBW with 3 concentric circles. The head has a built in washer that slopes down off the hex head. There are also marks of each of the 6 hex head flat spots that go toward the edge of the washer. And it has teeth on the bottom side to grip into the coil bracket. The threaded portion is 0.5" long. Does this make sense? This is for a 68. Anyone else have these on their original 68?
Martin
GaryL:
I have a '69. The same as a '68?
Marty:
I don't know for sure. I took these bolts off 68 cars that were not Camaros years ago.
Martin
JohnZ:
--- Quote from: GaryL on March 15, 2010, 01:10:05 PM ---I have a '69. The same as a '68?
--- End quote ---
Both '68 and '69 used the same coil bracket bolt (3848408), according to the A.I.M.
Navigation
[0] Message Index
[#] Next page
