Author Topic: 67' POWER STEERING PUMP PULLEY  (Read 5577 times)
SSMUNDY
  • TRIPLE BLACK 1967 CAMARO SS/RS CONVERTIBLE
« on: March 10, 2010, 03:50:16 PM »
I was wondering if anyone knew the difference between power steering pump pulley #3770509 and 3860457? They are both for a 1967 Camaro with v-8 engine. I know the first is for a 327, and the second is for a 350 ss. I'd like to know what the physical difference is between the two pulleys.
Sean
Marty
Re: 67' POWER STEERING PUMP PULLEY
« Reply #1 on: March 10, 2010, 09:51:51 PM »
I had examples of both but I only have a 457 now. The difference is the offset of the groove in relationship with the pump. One is further forward than the other but I can't remember which one. This affects the alignment with the crank and water pump pulleys. If you have the wrong pulley the belt won't be straight.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
SSMUNDY
« Reply #2 on: March 10, 2010, 10:50:47 PM »
Marty,
Thanks. That's what I was trying to determine. I have the 327 pulley, but I need the 350 pulley, the one you have. I purchased one through a local vendor, but it has the same offset as the one I have, so it's not the right one. I'll have to keep looking.
Sean
Marty
« Reply #3 on: March 12, 2010, 04:22:27 AM »
the 327 pulley is the 457
the 350 pulley is the 509
See the pulley chart on the site.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
