Author Topic: Need Help and or Advice  (Read 12353 times)
crownroyal58
« on: January 19, 2010, 01:56:19 AM »
I have a 69 camaro that i am pretty sure was originally a small block car, now it has a b.b. My problem is that after installing the engine it appears to me that it sets to far forward, there is plenty of room in between the block and firewall to acess the bell houseing bolts, most that i have seen are very tight. The the clutch adjustment rod is to short, the bell crank is angled foward, and when installing the crank pulley it has very little clearence, if any at the frame.
I realize that the b.b. requires special mounts that attach to the frame for the motor mounts, the ones i have, have these numbers stamped in them, the left side which is taller is 3950113, the right side is 3950114, both after market as well as the bell crank and clutch adjustment ass.
The 4-speed trans lined up with the trans mount with out any problem, the drive shaft measures 50" center to center. Does any one have ANY advice???
Is there a number stamped in the sub frame, and if so where?
crownroyal58
Re: Need Help and or Advice
« Reply #1 on: January 20, 2010, 01:28:53 AM »
Come on guys, I know that there is at least one expert in 1969 Camaros in this forum!!!!!!!!!! Plenty are looking, but no advice?
Steve68
« Reply #2 on: January 20, 2010, 01:39:15 PM »
Are you able to take some pictures and post them here?  That would help us to see the actual distance (place ruler in pic) from the wall, etc.
crownroyal58
« Reply #3 on: January 20, 2010, 03:44:53 PM »
Thank you , yes i do have pictures, but not with a rule. I will retake picture and hold rule against the firewall
crownroyal58
« Reply #4 on: January 21, 2010, 01:27:54 AM »
Steve,
Tried to send picture, but it said error, file to large, sorry i don't know how to copress and make smaller. For what it is worth the measurement you are looking for is 2 inches from the flat surface of the firewall to the back edge of the block. These measurements where taken on the right side of car.
Thanks, Mike
Steve68
« Reply #5 on: January 21, 2010, 01:47:49 AM »
I have a 396 in my 68.  Will check the spacing.  Will likely be tomorrow before I can get to it.
crownroyal58
« Reply #6 on: January 21, 2010, 01:52:50 AM »
Steve,
Trying to send picture, i think i may figured it out
crownroyal58
« Reply #7 on: January 21, 2010, 02:11:51 AM »
Here is Pic of My Problem!
Steve68
« Reply #8 on: January 22, 2010, 12:51:43 AM »
Checked my car and it looks like 2" is correct.  About 1-1/2 inches to the back of the distributor.  I could easily get my hand (size lg) down behind the block.  Hope this info helps you.
Mark
« Reply #9 on: January 22, 2010, 01:22:41 AM »
What is that picture, a crank pulley and a sway bar?  Gotta show a little more of the area.  If thats the sway bar passing in front of the pulley then its the wrong swaybar, because a 69 swaybar is bent so it follows the front edge of the subframe, it should not be a couple of inches up above the top of the subframe.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
crownroyal58
« Reply #10 on: January 22, 2010, 02:25:07 AM »
Thank You Steve, it does help to let me know the engine is not to far foward!
Mark, the black bar you see is part of the frame, not sway bar. Hope this picture gives you a better view.
Thanks for any advice i can get!!!!!!!
crownroyal58
« Reply #11 on: January 25, 2010, 12:57:31 AM »
 AFTER READING NUMEROUS POST I THOUGHT THERE WAS A GREAT DEAL OF WISDOM AND EXPERIENCE WITHIN THIS FORUM, MY MISTAKE! THANKS TO THOSE THAT DID MAKE THE EFFORT.
tom
    • Discount Internet Services
« Reply #12 on: January 25, 2010, 01:42:53 AM »
There is a lot of wisdom and experence here. Not all of it extends to all issues. I have a 69 automatic, but no big block experience. There is also a wealth of information outside of the forum, waiting for you on the rest of the site.
69 X11 Z21 L14 glide
o
nwsgjr
« Reply #13 on: January 28, 2010, 07:02:00 AM »
Just a thought but is that the right crank pulley...looks really deep...mine on my 68 bb is part #3921923 1-5/8 thick  and ... 6-3/4 straight across
crownroyal58
« Reply #14 on: January 28, 2010, 01:34:16 PM »
The Crank Pulley Is Part #3937787 Which Should Be Correct For A/C Car.
Thanks, Mike
