Author Topic: oil pan removal  (Read 5007 times)
ibfootin
oil pan removal
« on: December 27, 2009, 09:44:28 PM »
Will the pan drop out with engine still in car?  1969 with a 302
Gramps69Z
  • 69 X33 D80
Re: oil pan removal
« Reply #1 on: December 27, 2009, 10:00:10 PM »
Look on page 6-19 in the Chassis Service Manual.
Captain John Wykoff
ibfootin
Re: oil pan removal
« Reply #2 on: January 03, 2010, 01:52:48 PM »
Thanks.  I have the Chiltons manual and could not find it.  I will have to get the book you are referring to.
Happy New Year to all
hotrod68
  • almost finished
Re: oil pan removal
« Reply #3 on: January 04, 2010, 09:18:57 AM »
You can drop the lead pipes and clutch linkage, take out the engine mount bolts, take off the distributor cap, radiator hoses, the fan and shroud, then pick the front of the engine up with a chain hoist or a cherry picker. It will raise high enough to clear the crossmember at the front and let the pan drop out. Good luck!
ibfootin
Re: oil pan removal
« Reply #4 on: January 06, 2010, 01:50:29 AM »
Thanks.  It almost sounds like removal would be easier.
