Author Topic: 1968 standard rear tail light wiring harness  (Read 5077 times)
john302
« on: November 08, 2009, 08:16:44 PM »
What company makes the most correct rear taillight harness for a 68? thanks John
Lenny
  • 68 LeMans Blue Sport Coupe
Re: 1968 standard rear tail light wiring harness
« Reply #1 on: November 10, 2009, 03:50:52 PM »
When I replaced mine I believe I got it from "Ground-Up Restorations", 866-358-2277, Pt. #14195. It appears to be Mfg. by "M&H Electric Fabricators, Inc., www.wiringharness.com  I have a 68 Std Cpe and it matched great. I installed it and everything works fine. The only thing is that harness goes from under the dash inside at the firewall by the fuse block all the way to the rear, and also has a wire for the right door dome light switch that goes under the dash from the Left side to the Right side. It's up high above everything, gauges, radio, glove box, etc. There are clips up there to hold it in place. Good luck and Hope this Helps.....
Lenny
Lenny - Numbers Matching
Other Ride - -
62 Chevy "Biscayne"
2dr Post - BB
« Reply #2 on: November 10, 2009, 11:31:45 PM »
John, you could also try Lectric Limited...  http://www.lectriclimited.com/wiring-gm.htm
