Author Topic: Sheet Metal and Frame Rust removal  (Read 4114 times)
7sBlue
« on: November 08, 2009, 02:28:01 AM »
 Hi,  I am new to the forum, it looks like a lot of great information.  I am
just starting to restore our 1967 convertible and was wondering if anyone has
tried either rust removal product below with success.
http://www.d-rust-it.com/
http://www.safestrustremover.com/
Thanks for any input.
Doug
Re: Sheet Metal and Frame Rust removal
« Reply #1 on: November 08, 2009, 03:55:43 AM »
That safest rust remover has been recommended by a lot of people on Team Camaro and by some on here.  The people that use it swear by it.  I haven't used either one.
Buddy
« Reply #2 on: November 08, 2009, 03:23:39 PM »
What are you wanting to use it on/for??
Buddy
7sBlue
« Reply #3 on: November 08, 2009, 05:45:09 PM »
I am working in the rear of the car.  There is rust through in the rear quarter panels that I have
cut out an will replace.  The same with the outer wheel wells.  There is surface rust under and around the gas tank
area or the whole underside of the car.  I was thinking of sand blasting the underside of the car.  I have seen cars derusted using these products with a pump and pool type set-up to recycle the fluid. I was wondering which way may be better.
Stillwater Camaro
« Reply #4 on: November 13, 2009, 11:39:26 PM »
If you have the ability/availability to sand blast, I would choose that over a chemical that you may not get completely removed/neutralized.
1967 Camaro SS/RS 350
1966 Chevelle SS 396
1970 Chevelle SS 396
Buddy
« Reply #5 on: November 15, 2009, 03:37:10 PM »
Really depends on if its just a driver or are you restoring the car....
Surface rust can be converted to oxide with products like 'Rust Oleum Rust Restorer', you can get it at home depot. If you are restoring the car then I would go the sand blast route.
Buddy
