Author Topic: Engine Mounting  (Read 14386 times)
mark x22
Re: Engine Mounting
« Reply #15 on: September 28, 2009, 09:42:55 PM »
did it over  .
tom
    • Discount Internet Services
Re: Engine Mounting
« Reply #16 on: September 28, 2009, 11:35:48 PM »
Modern HEI style distributers have a rep for being a tight fit. Some worse than others.
http://www.camaros.org/forum/index.php?topic=1252.0
69 X11 Z21 L14 glide
o
Damon
  • 69 Camaro RS
    • www.damonr.com
Re: Engine Mounting
« Reply #17 on: September 29, 2009, 03:14:18 PM »
Mark,
Thanks!  Here is what I came up with:
Update 2,
Firewall to center of air cleaner stud 11.5" (you had 12.5")
Center of air cleaner screw to shroud 19.5"
Firewall to fan shroud 31 1/8" (you had 35.5") Maybe my shroud is thicker?
Firewall to hood latch 40 5/8"
Firewall to Shroud screw 35 1/2"
Alt Braket to fan shroud 4 11/16" (you had 3")
What do you think?
Thanks Mark!,
Damon
Damon
mark x22
Re: Engine Mounting
« Reply #18 on: September 30, 2009, 02:06:56 AM »
Firewall to fan shroud 31 1/8" (you had 35.5") Maybe my shroud is thicker? (the new picture is 29.88 ).( 35.5 is firewall to screw .) does your shroud match mine on the 5.62 in the picture ?
check this new picture 8.5 front edge of valve cover to fan shroud .the 29.88 - 8.5 = 21.38 from firewall to front edge of valve cover .
Damon
  • 69 Camaro RS
    • www.damonr.com
Re: Engine Mounting
« Reply #19 on: September 30, 2009, 04:45:03 PM »
HI Mark,
Will measure that.  Yes you shroud looks thicker to mine as half of my fan sticks out where it appears your fan all in the shroud.
Damon
Damon
