Author Topic: steering box  (Read 2894 times)
MarkB
steering box
« on: September 20, 2009, 03:17:41 PM »
What is the correct number of turns for a fast ratio steering box on a 1969 Z28.
MarkB
Re: steering box
« Reply #1 on: September 21, 2009, 02:59:39 PM »
The AMA specs submission shows 4.8 turns lock-to-lock for standard Camaro manual steering, and 3.5 turns lock-to-lock for Z/28 manual steering; standard Camaro power steering is 2.2, and Z/28 power steering is 2.06.
In both cases (manual and power), the ratio of the steering gear itself is the same between the standard Camaro and the Z/28, but the overall ratio is different - the Z/28 used different length pitman arms and steering arms on the spindles to reduce the overall ratio relative to the standard Camaro.
Jon Mello has more info on the N44 - it isn't covered in the AMA specs submission.
