Author Topic: 68 Z fan clutch  (Read 11145 times)
ccargo
Re: 68 Z fan clutch
« Reply #15 on: September 19, 2009, 04:01:36 AM »
So is it now acceptable to use the Eaton coil style clutch as "correct". I know John Z said that both were used and I'v seen an original 67 L78 with the Eaton??? I have the Eaton on a 68 L78 with the correct 4 rivet fan.
67 O-1 O4A L35 Convertible, Indy Zone IPC
fireZ
Re: 68 Z fan clutch
« Reply #16 on: September 19, 2009, 01:06:48 PM »
Not sure if they are correct but for my 68 Z thats all it will gets,as I cannot imagine spending 3 grand on the  correct one . ???
1968 Z28 LA Built
LIC # RPO Z28
Re: 68 Z fan clutch
« Reply #17 on: September 19, 2009, 01:20:25 PM »
The Eaton and Schwitzer clutches were used interchangeably on the line - that's what the "opt." (optional) part numbers are in the A.I.M.; different appearance, but same Engineering specs. What makes them hard to find (and expensive) is the unusual combination of the small (1-3/4") bolt circle where the clutch attaches to the water pump hub with the large (3-1/4") bolt circle where the fan attaches to the clutch. Most clutches that use the small bolt circle at the water pump also used the small (3") bolt circle for the fan.
Re: 68 Z fan clutch
« Reply #18 on: September 20, 2009, 04:39:39 AM »
Summit has the Hayden one for $30.
fireZ
Re: 68 Z fan clutch
« Reply #19 on: September 20, 2009, 11:54:01 AM »
Good to hear you found the Hayden part. The one on my car works fine and for 30 bucks compared to the NOS original om ebay now for 3000 its a  part that wiill do the job.
1968 Z28 LA Built
LIC # RPO Z28
