Author Topic: Gas tank date codes  (Read 138383 times)
ZLP955
Re: Gas tank date codes
« Reply #165 on: November 10, 2013, 05:36:02 AM »
Just pulled the tank from an 01B of 1969 VN coupe and it's stamped 21 69.
Tim in Australia.
1969 04A Van Nuys Z/28. Cortez Silver, Dark Blue interior, VE3 bumper, Z21, Z23, D55/U17, D80, flat hood.
Sold at Clippinger Chevrolet in Covina, CA. Ex-E/MP at Lions Dragstrip in Long Beach.
triumph675
« Reply #166 on: December 29, 2013, 05:23:38 AM »
Here's mine from a 1968 Norwood... Build date- 05C. Gas tank code is 68  43
triumph675
« Reply #167 on: December 29, 2013, 05:43:10 AM »
« Reply #168 on: December 30, 2013, 07:38:11 PM »
Here's the updated compilation. 67 has a calendar week code. 16 D 7 would be the 16th week of 67, day shift. 40 6N would be 40th week of 66, night shift.
The format changed in 68 and 69 to have the week counted from the beginning of the model year. The extended 69 model year used tanks dated for the 70 model year.
LOS and NOR data is intermixed and shows the same pattern.
11A  40 6N
??    52 N 6
02A   5 N 7
02C   5 D 7
02E   6 D 7  (stamped 7D6)
03B   9 D 7
03C 11 N 7
04B   4 N 7
04D   5 D
05C  16 D 7
10E  7 5 N  (7 may be a 2 and 5 is upside down)
11B  68 15
11C  68 17
12D  68 20
01C  68 19
02C  68 27
02D  68 32
02E  68 32
03C  68 34
04A  68 37
04D  68 41
05C  68 42
05C  68 43
05D  68 44
07C  68 52
07D  68 52
07D  68 53
09B   1 69
09B   1 69
10A   6 69
10C   4 69
10D  10 69
10D  10 69
11A  12 69
11C  11 69
11D  14 69
11D  15 69  (stamped 69 51)
11D  16 69
11D  17 69
12A  16 69
12B  17 69
12B  17 69
12C  16 69
12C  16 69
01B  21 69
01B  21 69
01C  21 69
01C  22 69
02A  25 69  (upside down 5)
02C  26 69
02D  28 69
02D  29 69
02D  29 69
02D  29 69
02D  29 69
03B  29 69
03D  45 69 - replaced?
03D  33 69
03D  33 69
03E  33 69
04A  33 69
04B  33 69
04C  37 69
04C  37 69
04C  37 69
04C  37 69
05A  37 69
05E  41 69
06A  41 69
06A  42 69
06A  45 69
07A  48 69
08A   1 70
08C   2 70
09A   5 70
09C   5 70
10A   9 70
10E  12 70
Any other 67 data?
Thanks!
-vellu
  • Camaro 1969 (08C) Vantaa - Finland - Europe
    • Camaro Club Finland
« Reply #169 on: January 02, 2014, 06:35:16 PM »
Nor 08C car and  2  70 code
67rs327
« Reply #170 on: April 05, 2014, 11:06:07 PM »
Here's a '67 for the list. Just pulled the tank last weekend on my '67 LOS 11A car. Code is 42  9D which doesn't seem quite right given the number 9. Could it be upside down and should be a 6?. Referencing some other posts -  the other 11A car listed  (40 6N) I believe is very close in production to mine - so go figure?
1967rs L30/M20 Bolero Red - LOS 11A.
Chris - New Hampshire.
« Reply #171 on: April 05, 2014, 11:18:58 PM »
Vellu same code as my 08C, good to know it was pretty uniform.
MyRed67
  • SZZLN 67
« Reply #172 on: April 05, 2014, 11:40:08 PM »
67rs327, Hi!  I'm Mike, the guy with the first tank on the list.    11A - 40 6N.  The plant production run # in upper right corner of my tag is A638, which would indicate it was actually built on the 1 st. of Nov.(per the A)  My car is also Bolero Red, unfortunately not as well optioned as yours.  It still has original 327 (was 2Bbl.,Powerglide) now built look just like a 302, "Day 2", with a built TH 350 and 4:11 12 bolt Posi.  Welcome, nice car!     BTW: my production run # is LOS  8031
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
67rs327
« Reply #173 on: April 06, 2014, 12:08:23 AM »
Hi Mike. I remembered you from some postings last summer when I picked up the car and you mentioned they were born close together. My trim tag corner code is D671 and the production run # is  LOS 8461.  So very close.  I've been picking thru the car off/on all winter  - and will be sure to stay in contact as these cars I'm sure have a lot in common. Chris
67rs327
« Reply #174 on: April 06, 2014, 12:52:18 AM »
Meant to attach this for reference.
MyRed67
  • SZZLN 67
« Reply #175 on: April 06, 2014, 03:43:09 AM »
Chris,  now that you mention it, yes I do remember some posts back and forth.  Wow, 430 cars, that is close.  As for the # in upper right corner, Nov. 1st. was on a Tues., so your # starting with D should have been Fri. of the same week.  But the 430 they could have built in 1 or 2 days.  Yours had more options so maybe it got held up a little.
1967 Camaro  LOS  11A
Leon in Mn.
« Reply #176 on: April 03, 2015, 08:50:34 PM »
Not sure if it is relevant anymore with all the gas tank codes already in the database, but I got finally around to looking at the gas tank code of my 67 03C today and found 11 N 7 on the tank.  LOS built car, built 3rd week of March puts it right in a few days before assembly the way it looks.  Also, the tank is painted black (looks like factory as this car has a lot of originality to it.)  I see someone already has the same numbers in the list.  11 N 7 would be 11th week of 67 night shift I believe?  Just my 2 cents worth without inflation!  :)
« Reply #177 on: April 03, 2015, 09:07:11 PM »
Its always relevant. We are always trying to gather more info about dated parts.
Leon in Mn.
« Reply #178 on: April 04, 2015, 08:11:45 PM »
No problem.  Glad I could be of some help.
Leon in Mn.
lynnbilodeau
« Reply #179 on: July 03, 2015, 09:17:30 PM »
Kurt.  You can add my 08A car to the mix.   Tank was dated 1 70.   I thought it was a replacement tank under warranty, as I did not know they started dating for 70 in Aug.
