May 23, 2013, 11:11:35 PM
Search:     Advanced search
82203 Posts in 10502 Topics by 4351 Members
Latest Member: Oldblue69
+  CRG Discussion Forum
| |-+  Originality
| | |-+  sealing compound
« previous next »
Pages: [1] Print
Author Topic: sealing compound  (Read 1397 times)
68Zproject
Hero Member
View Profile Email
« on: June 24, 2009, 07:11:56 PM »
Did the factory use the grey thin ropes that I always called dum dum, for sealing the door water shields and the air vents in the kick panel?  Or did they use black in some places, grey in others etc?
Logged
68Z28
Big_Al
Member
'69 L65 RS X11 Z87 Z21 713 40B DX1
View Profile
« Reply #1 on: June 24, 2009, 07:31:07 PM »
My '69 has grey on the door water shields, can't say about the kick panels.
Al
Logged
I've owned three Camaros, '67 RS 327 convertible, '69 RS 350 coupe and a '73 Type LT 350 coupe with split bumper.
Oregonjam
Member
68 ss350
View Profile Email
« Reply #2 on: June 25, 2009, 08:47:14 AM »
The compound I have seen on Kick panels had a tan appearance. This was on two vehicles both 68 with AC. Other smay be able to confirm or disprov ethis. I believe that neither of these vehicles had the panles out previously. This is the only part I have seen Tan on however.
Logged
68 07D SS350
John
Stingr69
Member
View Profile Email
« Reply #3 on: June 25, 2009, 03:10:16 PM »
It was very close to the gray 3M Dum Dum but it had a string in it, presumably to help with handling the stuff. You can use the 3M strip caulk in a box to be very close to original minus the string. Plumbers putty works well too.  Smiley
-Mark.
Logged
Oregonjam
Member
68 ss350
View Profile Email
« Reply #4 on: June 25, 2009, 04:59:02 PM »
This is what I use and was also recommended on another thread.
3M strip caulk part#08578 black
You can get it at pretty much any automotive supplies dealer , Napa, O'reilly etc.
Logged
68 07D SS350
John
68Zproject
Hero Member
View Profile Email
« Reply #5 on: June 26, 2009, 01:22:49 AM »
I had an SS in H.S. and it was only 6 years old so most of the stuff was original.  The kick panel had grey sealer but there was black on the door shields.  I just wondered if there was a specific kind for certain areas or if they just used both or whatever was available.  I know there is a lot that we know about the assembly process, but some of these little details are scarce it seems.  I would like to know what people that restore cars use for a reference to get all these details.
Logged
68Z28
Pex68
Member
View Profile Email
« Reply #6 on: July 07, 2009, 03:05:02 PM »
On my car kick panels were sealed with grey seam sealer from a tube and dries hard.  See photo.  It's available from auto body shops in a caulk tube. The dum dum was used on the water shields and lower window track bolt.  Strip Caulk is the same stuff.
Logged
Chris P
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.075 seconds with 18 queries.
