Author Topic: Block Casting # 3955272  (Read 22004 times)
dhf69ss
« on: May 17, 2009, 02:41:35 AM »
Can you confirm that this block (3955272) is a L78 396 375HP.
What heads and intake should the engine have from the factory ??
Thanks for the help.........69 SS 396
Re: Block Casting # 3955272
« Reply #1 on: May 17, 2009, 03:02:52 AM »
In 1969, the 3955272 block was used in various horse power configurations ranging from 265 to 375. To verify it's a 375, it has to be a 4 bolt main with the correct engine suffix code. What's the suffix code and VIN on your block?
dhf69ss
« Reply #2 on: May 17, 2009, 10:54:41 PM »
Hi Ed,
 Thanks for your reply. That confirms what I have found also.
 The suffix code is T1108JA.( It is not the original motor but correct date code
for the car.)
 Some numbers decodes say it is a L78 396 375 (Year One) others say it is a L35 396 325.
 What do you say ??
Thanks again,
Dan
« Reply #3 on: May 17, 2009, 11:34:51 PM »
For 1969, JA is a 396/325 from a Chevelle. Yours was assembled at the Tonawanda, New York engine plant on November 8th, 1968.
