Author Topic: Brake light bracket ???  (Read 2503 times)
Metal Man
« on: May 04, 2009, 05:56:20 PM »
Is this bracket original, It’s hitting my column.
I dissembled the car years ago and don’t remember if it is mounted correctly.
KevinW
Re: Brake light bracket ???
« Reply #1 on: May 04, 2009, 07:36:36 PM »
Nope.  The bracket is mounted in the upper hole so that the flat part hits the brake switch.  The reason was that power brakes located the brake pedal lower than manual, so they needed a little filler to make up the distance.
« Reply #2 on: May 04, 2009, 07:40:00 PM »
See the Assembly Manual, section J50, sheet A3, items 1, 2, and 3.
