Author Topic: Correct Alternator for 68 rs/ss 350.  (Read 13533 times)
blownonfuel
« on: March 21, 2009, 06:27:18 PM »
What would be the correct alternator for a 68 rs/ss 350 auto/ w/ac. No power options in the interior.
Re: Correct Alternator for 68 rs/ss 350.
« Reply #1 on: March 21, 2009, 06:55:37 PM »
1100796
kforce
« Reply #2 on: March 21, 2009, 07:20:04 PM »
Colvin's "By the Numbers" says:
Camaro - 61 Amp - 1100796 - A/C Ex. 6-Cyl. Smog Control or P.S.
             61 Amp - 1100817 - A/C 6-Cyl. Smog Control or P.S.
1967 RS/SS 350 - PG - Sierra Fawn - Black Vinyl - Gold Deluxe
1974 Z/28 - 4-speed - Silver (with those ridiculous stripes)  Black Interior
1998 Z/28 - 6-speed - Bright green - Convertible
kforce
« Reply #3 on: March 21, 2009, 08:30:29 PM »
Jason Scott's book lists the 1100817 as: 61 Amp - 68 w/: a/c. AIR or PS
Confusing.
So if the Car was V-8 or 6 cylinder with Air Conditioning AND had either A.I.R. or Power Steering or both,
it got the "817"?
blownonfuel
« Reply #4 on: March 21, 2009, 08:55:11 PM »
Confusing.
it got the "817"?
Thanks. What about the starter for the same car? 68 SS350
« Reply #5 on: March 21, 2009, 09:14:37 PM »
You want even more confusion? Here's what the 68 Chassis Service Manual says:
1100796 - All V8 W/C60 AND C75, all L6 W/C60 AND C75 EXC K19 and N40 (So... what the hell is C75??)
1100817 - All L6 W/K79 AND K19, and/or N40
1100814 Camaro 302 WITH C60. (Since when did the Z28 come with A/C!!!)
And according to the same manual, the correct starter would be the 1107368, BUT I don't think this is correct either. Mark will know for sure, but I think it's 1107365. The P&A shows it to be either the 1107365 or the 1107388, but I think the 388 is a service replacement.
So you can see that even GM documentation is totally screwed up when it comes to alternators and starters!
Mark???
« Last Edit: March 21, 2009, 09:26:34 PM by bertfam »
blownonfuel
« Reply #6 on: March 21, 2009, 10:18:09 PM »
Mark???
Thanks Ed. Man that is confusing.
« Reply #7 on: March 21, 2009, 10:37:38 PM »
blownonfuel
« Reply #10 on: March 22, 2009, 05:31:57 AM »
C75 is the climate control (you set the desired interior temp) version of AC. Fancy-smancy back then, available on the full-size cars.
« Reply #11 on: March 22, 2009, 03:34:51 PM »
We have to keep in mind that the P&A books list parts that will "service" the application functionally, and frequently reflect parts consolidation to keep parts proliferation at a minumum in the Service inventories; Service part numbers are seldom the same as the production-line parts, especially if more than a year or two has passed since the car was built.
ms69z28rs
« Reply #13 on: April 09, 2020, 01:12:29 PM »
Hi all, What would be the correct alternator for a 68 Camaro SS 350 convertible with power steering, power top and smog, obviously no ac. I was told it would be a 1100794 37amp. Thanks Michael
« Reply #14 on: April 09, 2020, 01:25:35 PM »
Quote
That's correct Michael. The 1100794 was the standard alternator for all V8 engines except the Z28 302.
