Author Topic: Howdy! ...and a Fan blade question  (Read 10131 times)
MMMM_ERT
« on: March 08, 2006, 06:44:28 AM »
Hi folks,
I'm new to this board.  Some of you may remember me, I used to be on the old f-body-classic email list.  Pete Serino is the name and I still have my gorgeous 68 Camaro.   ;D
Got a few questions and I searched the board for an answer but nothing came up.  This relates to an original fan-blade for my car.  I have long since replaced the original fan blade with an aftermarket fan (original got bent to heck when the water pump froze up and went through my radiator. ARgggh!)  Anyway, I am wanting to go back to an original 5-blade fan and fan-clutch (my car has original A/C)  I've been looking for  a fan for a while...a few 5-bladers show up on eBay, but no part numbers or just an "H" on them.
Any input on where to find a good original fan?   What is the bolt hole spacing of said fan?  I read on CRG site something about 3" diameter for my application and 3.25 for big block or Z28.  What is the dimention between holes center to center?
Anyway, heres a pic of my car.   She made the Dan Lyons 2004 Camaro Calendar!
Thanks for your help!
-Pete
1968 Camaro RS/SS 350 Coupe
lakeholme
  • 68-12D L30/M35
Re: Howdy! ...and a Fan blade question
« Reply #1 on: March 09, 2006, 07:04:36 PM »
I do not keep my 68 (with AC) at my home, but I will measure the fan holes center to center over the weedend.  I see from the picture (by the way, great car!) that you have a 350.  Mine is a 327, but after looking at the service and assembly manuals, I THINK they are the same.  (To be honest, I've got a great freind who is a specialty mechanic and he does all my AC and electrical work.  AC is a mystery to me... but much loved in July in NC!)
If this will help in your search, the 68 assembly manual refers from the V-8 page to the RPO K02 page about the fan.  There, it refers to the fan (and it does show a five-blade in the drawing) as "3789562 Blade Asm - Fan" and the clutch as "3916139 Clutch Asm".  Not having my car here, I will have to check if my fan has the same or similar numbers this weekend.  I do not know.
Of course, someone (hint, hint) may see this and go ahead and give you an answer....
Phillip, HNR-AACA, Senior Master, Team Captain
Spring Southeastern Meet chair
Fall Charlotte Autofair, Sept. 6-9, 2018
2019 Glidden Tour Host
MMMM_ERT
« Reply #2 on: March 10, 2006, 06:35:16 AM »
Thanks!   :)
I do have the factory assembly manual and checked the "K02" option, it does show part numbers but not "dimensions".  Most of the 5-blade fans on eBay seem to not have an original part number...just and "H" or "W" on them and marked "front".   I am trying to figure out the difference that CRG calls out with the 3" or 3.25" on the fans.
I also see fan clutches on eBay with the part number 3916141 and they claim they are for 68 small block 327 or 350.   Wondering if these will work?  I don't care if the part number is correct so much.  My car is not totally original anyway.
« Reply #3 on: March 10, 2006, 08:41:07 AM »
The center lines of the four bolt holes are in a 3" or a 3.25" diameter circle.
MMMM_ERT
« Reply #4 on: March 10, 2006, 07:24:42 PM »
Thanks for the response Kurt.
I guess I'm still a bit confused, I have a small block so it should be the 3" diameter, correct?
The CRG page shows this:
Clutch Fans
In 1967 and 1968, the clutch fan was 18 inches in diameter, had five blades, and came in two types:
1967-68 fan for AC or K02 cars
For cars with hydraulic lifter engines with AC or K02 (except 1968 L34/L35 with K02), the 3789562 fan with a 3-inch diameter clutch-to-fan attachment bolt circle was installed. Three different fan clutch part numbers are listed as having been used with this fan, all having the matching 3-inch diameter bolt circle.
1967-68 fan for L78 and Z28 and 1968 L34/L35 with K02
The 3871276 fan was used on the 1967 and 1968 Z28 and L78, as well as 1968 L34/L35 with K02. The bolt circle diameter for the clutch-to-fan attachment was 3.25-inch.
lakeholme
  • 68-12D L30/M35
« Reply #5 on: March 12, 2006, 12:50:06 AM »
I looked my five blade fan over, and you are right, I found no numbers.
I thought sure it would be 3-inch, but it looks like it is 3.25. (center to center)
I do know my motor is not orginal, but it is a 327 and the fan fits fine... and the air works great.
Not sure I really helped you, but good luck
« Last Edit: September 14, 2006, 05:07:50 PM by lakeholme »
MMMM_ERT
« Reply #6 on: March 13, 2006, 05:07:27 AM »
Thanks Lake!  :)
« Reply #7 on: March 13, 2006, 05:28:04 AM »
The CRG page shows this:  ........
That's the difference, hence my response above.
Yes, you should have the 3" version.
Lake,
Make sure you measure to the centerline of the holes, not to the edges.
lakeholme
  • 68-12D L30/M35
« Reply #8 on: March 14, 2006, 02:24:46 AM »
I really did measure it center to center.  But I'll go back and do it, again!  .25" isn't that big a difference, so I'll make doubly sure and let you know. ;D
So, are 3" for small block and 3.25" for big block? ???
MMMM_ERT
« Reply #9 on: March 14, 2006, 02:30:26 AM »
I guess I wasn't descriptive enough....
So...given the difference from SB to BB...the clutch itself must have a matching bolt pattern.
« Reply #10 on: March 15, 2006, 05:33:50 AM »
Yes, the two fans require different clutches. I'll reword that part of the article.
MMMM_ERT
« Reply #11 on: March 15, 2006, 06:29:22 PM »
Thanks Kurt.
18" 5-blade fans are hard to find (in decent condition)  GM still carries a 17" 5-blade fan which is technically for a 60-67 Vette but has the correct 3" center to center holes for the fan clutch.
Any reason going to a smaller 17" 5-blade fan would be a bad idea?
« Reply #12 on: March 15, 2006, 10:50:22 PM »
Yes. It won't fit correctly/completely in the fan shroud and you won't get the cooling you want.
