Author Topic: 69 Z28 Cowl Induction Airhorn  (Read 9028 times)
« on: December 22, 2008, 09:04:45 PM »
Does anyone know of a readily availalbe Air Cleaner which has the same airhorn as the Cowl Induction AC for a '69 Z28?
L78 steve
Re: 69 Z28 Cowl Induction Airhorn
« Reply #1 on: December 23, 2008, 04:29:53 AM »
The closest repop is by The Parts Place Inc. Flat bottom with the notch on the snorkle .
69 Z/28 Dover White. SOLD
« Reply #2 on: December 23, 2008, 06:18:17 AM »
I have an original Z28 Cowl AC with the airhorn cut off.... so I need an airhorn that is right (an original one) not repro....  someone has said that any 4 bbl 350 AC from 69 has the same airhorn...?  Are there others that use the same airhorn?   My AC is perfect except for the missing airhorn....
wtexz10
« Reply #3 on: December 23, 2008, 07:44:49 PM »
Are you saying you have a Z28 air horn for use with Air conditioning?  Not sure if the air horns are the same for ac and non ac cars, but Z28's did not come with AC.
KB
69 Camaro Z10.. 72 GMC C1500
79 Mazda RX7.. 79 Trans Am WS6
06 Corvette Z06.. 10 BMW 650i
L78 steve
« Reply #4 on: December 23, 2008, 10:47:42 PM »
You have to find one w/o the thermac valve .SHP only .
Dusk Blue Z
« Reply #5 on: December 23, 2008, 11:20:26 PM »
I think the AC is short for Air Cleaner.
1969 Z/28 Legends Certified
1969 Z-10 Under Construction
« Reply #6 on: December 26, 2008, 05:11:39 AM »
Yeah, my apologies to anyone who misunderstood...  I was shorthanding Air Cleaner with AC... thinking it would be clear.   I have a second original Z28 Cowl air cleaner with some extra dings on the bottom..  I'm trying to avoid canniabalizing that one to get the correct airhorn to fix my original one....
L78 steve
« Reply #7 on: December 28, 2008, 08:23:13 PM »
The snorkle on any 69 V8 air cleaner will be the same, you just need to find one w/o the thermac .
« Reply #8 on: January 06, 2009, 05:37:47 PM »
thanks L78 Steve...    :)    Now I just need to find a banged up one with a good snorkel   :)
mjbake
« Reply #9 on: January 06, 2009, 06:17:46 PM »
Look under general today. Someone was asking how much something like you need is worth.
Mike,
67 L30/M20
Convertible
« Reply #10 on: January 08, 2009, 11:39:41 PM »
Thanks..  I just read this, but I'm looking now..  :)  uhoh.   I just saw it.   That was for a GM NORS A/C...   not worth buying that just to remove the snorkel..  :)       and the A/C exhibits a later change from factory original '69.
