CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
May 24, 2013, 04:16:48 AM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
82213 Posts in 10503 Topics by 4351 Members
Latest Member: Oldblue69
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  Originality
| | |-+  1969 radiator fan
« previous next »
Pages: [1] 2  All Print
Author Topic: 1969 radiator fan  (Read 2820 times)
69houdini
Member
69 SS X55 Butternut Vert / 69 RS SS Coupe L48 /
View Profile Email
« on: December 15, 2008, 02:49:32 PM »
 Hey guys , I am taking off my dealer added air that was added on back when the car was P/U at the dealers in 69, they did a terrible job on it. I want it to be correct. Thing is it has a 6 blade non numbered fan and everything I read s/b a 4, 5 or 7 blade fan. I read about the non numbered fan but nothing was said about the 6 blades. Any insight or info you can give me would surely help. Thanks
Logged
Hero Member
View Profile
« Reply #1 on: December 15, 2008, 03:22:01 PM »
http://www.camaros.org/coolingsystems.shtml
Logged
69houdini
Member
View Profile Email
« Reply #2 on: December 15, 2008, 09:57:43 PM »
Hi Kurt,    Yes I read your report before I posted. I did do more digging and found the exact same fan on e-bay and in the Classic Industries catalog. They have been making this fan for a long long time. Your report lead me to what I really needed to be correct so a big thanks to you.  -John
Logged
69houdini
Member
View Profile Email
« Reply #3 on: December 15, 2008, 10:15:40 PM »
Sorry Paul, I meant to thank you but had Kurts report on my mind. Must all 7 blade fans have clutches?
Logged
CRG Coordinator
View Profile Email
« Reply #4 on: December 16, 2008, 10:49:45 AM »
In 69, all 7 blade fans have clutches in Camaros.
Logged
Pacecarjeff
Member
View Profile WWW
« Reply #5 on: December 16, 2008, 10:13:29 PM »
The 6 blade fan is very common for Pontiac, Cadillac, Buick, and Olds.
It was used on many A/C cars in the 60's and 70's.
For those manufactures -- it was their High Perf fan.
Chevrolet never used a fan with 6 blades back then.
Logged
srode
Member
View Profile Email
« Reply #6 on: April 17, 2012, 04:07:05 AM »
So from reading the article a 69 pace car without AC and with a 350 should have a 4 blade fan and not a clutch fan?
Logged
CRG Coordinator
View Profile Email
« Reply #7 on: April 17, 2012, 12:05:32 PM »
More than 97% of  SS's had the 4-blade fan.
Logged
srode
Member
View Profile Email
« Reply #8 on: April 17, 2012, 08:27:57 PM »
thanks Kurt, I wouldn't have guessed that , but after reading this post suspected - nice to have confirmation.
Logged
CRG Coordinator
View Profile Email
« Reply #9 on: April 17, 2012, 09:22:40 PM »
Good point, I can add that clarification to the article.
It does say "So yes, your SS350 or SS396 (325hp or 350 hp), if without AC, likely came with the standard four-blade fixed fan. " But it will be clearer with percentages.
Logged
Pacecarjeff
Member
View Profile WWW
« Reply #10 on: April 20, 2012, 08:17:07 AM »
Unless the HD cooling option was ordered - there were a good number of SS350 cars that had a clutch fan.
Check your radiator code before assuming...
Logged
srode
Member
View Profile Email
« Reply #11 on: April 20, 2012, 06:41:21 PM »
Are the blades on the original clutch fans steel or aluminum?  Not the center hub but the blades.
Logged
CRG Member
View Profile Email
« Reply #12 on: April 21, 2012, 10:49:53 AM »
The blades on the "772" fan are aluminum; don't know about the others.
Logged
Pacecarjeff
Member
View Profile WWW
« Reply #13 on: April 21, 2012, 03:35:05 PM »
5 blade Camaro fans have steel blades.
The 4 blade fans don't really have "blades" - the unit is steel stamped in two parts and riveted together.
Logged
Hero Member
View Profile
« Reply #14 on: April 21, 2012, 04:02:35 PM »
And yes.....those steel blades sure play havoc on timing light cables  Grin
Logged
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.093 seconds with 17 queries.
