Author Topic: 1996 camaro park lamp fuse keeps poping  (Read 2325 times)
robertsanjose
« on: December 04, 2008, 06:42:03 PM »
has anyone ran into this problem and if so how do i fix it?
tom
    • Discount Internet Services
Re: 1996 camaro park lamp fuse keeps poping
« Reply #1 on: December 05, 2008, 02:09:30 AM »
Sounds like a wire with worn insulation. When it shorts the fuse pops. I would start with a visual inspection of the circuit. Work your way back from the bulbs to the switch. If you can spot the insulation being worn, or damaged that could be your problem. A temp fix can be a simple as wrapping the spot with electrical tape. If the problem is solved, then replace that section of wire.
69 X11 Z21 L14 glide
o
