Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
Correct finish(es) on 69 12-bolt Camaro rear
« previous
next »
Print
Pages:
1
2
All
Author
Topic: Correct finish(es) on 69 12-bolt Camaro rear (Read 22391 times)
68rsssrag
Member
Re: Correct finish(es) on 69 12-bolt Camaro rear
Reply #15 on:
March 13, 2006, 01:17:40 AM »
I have a 1968 12 bolt with posi. Originally the axle carriers and center were not painted. Can this be?
Arno
Logged
nuch_ss396
Member
Reply #16 on:
March 13, 2006, 03:38:12 AM »
I just received these images from CRG member "Tinkerr" and posted them at his request.
Thanks for your assistance Paul !
THM400 driveshaft ( left ):
THM400 driveshaft ( bottom ):
Logged
Steve A.
nuch_ss396
Member
Reply #17 on:
March 13, 2006, 03:48:08 AM »
Paul?
Are the THM400 u-joint end-caps of a slightly larger diameter that the standard ( smaller ) u-joint end-caps?
Is your THM400 driveshaft original? I'd love to see one of those u-joints in detail.........
Logged
Steve A.
Tinkerr
Member
Reply #18 on:
March 13, 2006, 04:52:52 AM »
Steve,
The t/400 u-joint caps are slightly larger outside diameter.I attempted to place a cap from the other u-joint on the t/400 u-joint, it won't fit inside diameter is to small.
Hope this helps
Logged
Print
Pages:
1
2
All
« previous
next »
Originality
