Author Topic: How do I install a bayonet style stick into the shifter  (Read 4542 times)
jg4now
« on: November 13, 2008, 09:38:11 PM »
I recently purchased a rebuil kit for my 1969 hurst shifter.  I am at the point where I need to reinstall the bayonet style handle in the receiver.  Does anyone know how is this done?
hihorse
Re: How do I install a bayonet style stick into the shifter
« Reply #1 on: November 14, 2008, 02:21:05 AM »
installing is easy, most have problems getting the stick out
GaryL
  • Marilyn and me
« Reply #2 on: November 14, 2008, 03:44:57 AM »
Put it in the slot and push down hard.
Gary
JoeC
« Reply #3 on: November 14, 2008, 05:48:24 PM »
you need the 2 rubber parts and 2 metal locking shim parts. This all goes together with the shifter stick to make a sandwich that holds it in
jg4now
« Reply #4 on: November 17, 2008, 01:34:27 PM »
Thanks for the replies.  I ended up destroying the isolators trying to push the handle in.  The handle wouuld go in about 1/3 of the way and then the rubber isolators began to slide out of the other end when I applied more muscle.  Anyway, after destroying them, I purchased a new set and used the same procedure without any issues.  The rubber isolators in the first set must have been too thick.
Thanks again for the replies.
