Author Topic: Wiper Motor  (Read 8750 times)
flyingskibiker
Re: Wiper Motor
« Reply #15 on: July 15, 2010, 10:12:23 PM »
Yes.  I bought a complete grommet kit that has the grommets, ground tab, and metal washers/sleeves.  Most of the usual vendors have them.
nwbalddog
Re: Wiper Motor
« Reply #16 on: July 15, 2010, 10:53:19 PM »
Did you swap out the brass tab, and if so how did you get the old one out and new one in?
1969 Camarao Convertible
396/SS/RS/Auto
flyingskibiker
Re: Wiper Motor
« Reply #17 on: July 17, 2010, 08:57:18 PM »
I plan on swapping out the whole kit.  I just dug it out of my parts bin.  It looks to me like the brass O ring/spade is just captured between the sleeve and grommet.  It freely spins around the sleeve.  So, I would say that if one pulled the sleeve out of the grommet, the brass ring would just come off.  I guess after many years in place, it could have become more perminately attached.?.?
KevinW
Re: Wiper Motor
« Reply #18 on: July 20, 2010, 10:38:05 AM »
The brass ring's tab is sandwiched between the plate halves to provide a good ground path.  If it comes out of the paltes, then there is your problem. You have to seperarate the plate halves (riveted together) to get the brass tab out.
