Author Topic: Three Holes in Frame for Clutch Z bar (Cross Shaft) Bracket, Bolt Size ?  (Read 3403 times)
Camaroon
Greetings.
There are three holes in the drivers side of the '68 frame for mounting the bracket that holds the clutch cross shaft ( Z Bar, bellcrank, lever, whatever you like to call it).
These holes appear to be threaded, tapped for bolts.
Anyone know what size (diameter) bolt and weather they are coarse or fine thread?
Thanks...!
Re: Three Holes in Frame for Clutch Z bar (Cross Shaft) Bracket, Bolt Size ?
« Reply #1 on: October 19, 2008, 08:46:20 PM »
5/16" - 18 x 1/2" is the size of the original ones.
Also, the original ones on my '68...
a)  Are grade 5
b)  Have an "EL" marking in the center of the bolt head.
c)  Have an encapsulated lock washer on them.
Also, per the '68 AIM the part number is 9420603 and their torque spec is 120-180 lbs in.     :)
Camaroon
« Reply #2 on: October 20, 2008, 12:54:14 PM »
Wow....!
Thanks, Paul, for the quick and detailed answer !
You are the man!
Have a great week.
Thanks again.
