Author Topic: 69 Z questions  (Read 5551 times)
jdv69z
  • 69 RS Z/28 52E
69 Z questions
« on: September 02, 2008, 04:24:20 PM »
Am working on my 69 Z and have two questions:
1. I'm trying to remove the clutch fan/pulley from the water pump; Have removed the nuts from the studs, but the fan and pulley don't want to come off. I don't want to doing prying, etc. or I'll need a new water pump. Anyone have this problem and a solution?
2. I need to re-wrap some wiring in the engine bay. What is the tape that I need? Original looks like black friction tape? Wires are to starter so come close to engine block. Anything that resists heat that might be recommended?
Jimmy V.
Jimmy V.
Pacecarjeff
    • pacecarjeff.com
Re: 69 Z questions
« Reply #1 on: September 02, 2008, 07:46:41 PM »
For your fan clutch - I always just use a big hammer.
Just give it one good wack - that will get it off.
GaryL
  • Marilyn and me
Re: 69 Z questions
« Reply #2 on: September 03, 2008, 03:49:10 AM »
The wrap for the wiring harnesses was just a black plastic tape with no adhesive. Rick's sells it. #RC-508. If they sell it then most stores will have it.
Gary
Re: 69 Z questions
« Reply #3 on: September 05, 2008, 03:12:57 PM »
There is a cloth type tape and I believe that is what you are referring to when you say "friction tape" I believe the cloth tape is more resistant to heat and wear...
Re: 69 Z questions
« Reply #4 on: September 05, 2008, 03:20:59 PM »
The cloth-type tape will get deductions in judging, as the original harnesses were wrapped with non-adhesive shiny black plastic tape, as noted by Gary.
jdv69z
  • 69 RS Z/28 52E
Re: 69 Z questions
« Reply #5 on: September 05, 2008, 08:06:50 PM »
Thanks, I'm getting the tape from Rick's. No issues with judging; my car is a very nice driver and doesn't attend many shows; mostly country roads on nice weekend afternoons.
Jimmy V.
Jimmy V.
